check light came on again! p0757
Last night, when I came home, after driving for about 30 minutes, about 2 minutes away from parking, the check light came on. When I pulled up into my driveway (not very steep at all), the car died! It took probably about 3 times for me to get it all the way into the garage, and I noticed that I had to give it considerably more gas just to get the thing in the garage. I had a PO757 a few weeks ago, but after I reset it, it has driven perfectly since them. Should I be concerned? I wouldn't be except it seemed like it was difficult to drive it up into the garage.
Today I drove it around for about 10 miles - got on it a few times and everything - it all felt great. What gives?
I have a 231/234 640/610 cam, vigilante 3200 stall, stg 2 a4, 3.73's and a bunch of bolt ons.
wow thanks so much for the quick reply! my concern was that it seemed to mechanically effect the vehicle, ie - me having to really really push it in order to get it in the garage at only a few degree incline. Is that common and something i should not be concerned about?
limp mode leaves you with 2nd and 3rd gear only, no first, (which would explain why it seemed to take a lot to get moving) no overdrive, and no lock-up.
tuning SHOULD take care of it if the car is not calibrated for the torque converter.
