LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Converter Guru's plz (https://ls1tech.com/forums/automatic-transmission/830416-converter-gurus-plz.html)
01ramair500hp Dec 15, 2007 07:50 AM
i am building a turbo408. iron block with a pt101. running 22 lbs. plan on making 1200 rwhp. i have an old school th400 built. any converter reccomendations. i called niel chance to spec one but the price seemed a little high. i guess u get what u pay for. any reccomendations on this ?
thx
Hunter
Gilbert@Ace Racing Dec 15, 2007 08:30 AM
Stay away from any 8" housings, they will stall too high.
A 9-1/2" or 10" unit would work just fine. You'll need to keep it on the tighter side... under 4,000 rpm stall. I highly recommend that all of the fins be tig welded in place after the stall has been set. It needs to have a billet front cover for the sake of durability and consistancy. I recommend a steel stator. It should also have an anti -ballooning plate.
If you would like to discuss what we could do for you just give me a call. I am confident we could build you a unit you would be satisfied with.
g
© 2026 MH Sub I, LLC dba Internet Brands
