john 67 | 03-18-2008 07:50 PM | 4l80e conversion cooling line question i am currently installing a new ls2 coupled to a stock 99 4l80e trans with 373's in a 67 chevelle. the trans is really tight and i couldnt re-use the old lines coming out of the trans, so i had inline tube make a push connect flare with a short elbow which is slightly different than gm's lines .i think it should work.Are there any other options for me such as a special fitting to turn directly out of the trans? and does anyone make the same gm flare? any input or tips would be appreciated . thanks JOHN |
