a4 with 3200 vig and 410's in a 12 bolt????
Old Jul 23, 2003 | 09:10 PM
pascal's Avatar
Default a4 with 3200 vig and 410's in a 12 bolt????
is this going to work or stay with 373"s.with o.d. highway travel should be ok ,right ??? thks.
Old Jul 23, 2003 | 10:31 PM
Kent1's Avatar
Default Re: a4 with 3200 vig and 410's in a 12 bolt????
From my experience with both gears, I would go with 3:73's. BTW, I have had the vig. 3200 with 3:73's and it is a good combination. Cheers
Old Jul 23, 2003 | 10:53 PM
pascal's Avatar
thks. kent1,2 questions,did your vig. tc have any vibration and how did you come out with the car on the starting line.i have never run a verter so the starts are new to me.i have et streets to aid tracton. thks.
Old Aug 3, 2003 | 08:55 PM
Kent1's Avatar
There were no vibrations with the 3200. Generally rev the car up to 1100 RPM's off the footbrake. It varies from car to car. Sixty foots range from 1.63 to 1.70 with Hal shocks on Nittos. Nittos require a long burnout and hit line ASAP. Cheers.
Old Aug 4, 2003 | 02:21 PM
Elite_Hot_Rod's Avatar
I had a Vig 3200 and 3:73's and I launched at idle (900 RPM). I routinely cut low 1.60 60ft's, with a best of 1.584.
