LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   4L60E won't upshift at the drags (https://ls1tech.com/forums/automatic-transmission/906260-4l60e-wont-upshift-drags.html)
SQ1110 Apr 20, 2008 08:06 PM
My $l60E works great in drive,but when it hooks real hard at the track or on the street it wont come out of first until i lift,then it goes right to third. Also,after this happens, it has no first gear or overdrive until after i park it or shut it off,then everything works fine again,its a fairly fresh trans with an ATI ten inch converter And a 4.10 12 bolt.Other than that its bone stock. Would a fluid level be a possibility? It's dead in the middle of the level range.Please help I need to do some bracket racing.Thanks,Shaun
900hpSS Apr 20, 2008 10:05 PM
usually when they default to third it is because it has over heated.
SQ1110 Apr 21, 2008 03:57 PM
Thanks, I appreciate it.
© 2026 MH Sub I, LLC dba Internet Brands
