trans coolers, 1? can i run 2? any advantages or disadvantages?
Old 04-29-2008, 01:59 PM
4SFEDZ's Avatar
Default trans coolers, 1? can i run 2? any advantages or disadvantages?
ok im new to the auto world, but im goin to be runnin a th400 on the street. it has a tbrake and i was told they make them run a little hot. but whats the best cooler, and can i run two coolers without any problem? would runin 2 cause flow or presure probs?
Old 04-29-2008, 05:50 PM
ta_06374's Avatar
I run the stock cooler and a aftermarket cooler.
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I ran two aftermarket coolers with the stocker bypassed. I probably will on any car I build
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-29-2008, 05:59 PM
LS1Tech Sponsor
performabuilt2's Avatar
i have used an a/c condensor as a cooler before It was on a truck with 44 inch tires and a 3500 stall it was the only thing that kept it cool lol
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 04-29-2008, 06:50 PM
N.Etheridge's Avatar
Now thats useing your head!!!!!!!!
Old 04-29-2008, 08:20 PM
jsteele90's Avatar
i like it
Old 04-29-2008, 08:26 PM
LS1Tech Sponsor
lol held an extra 5 quarts of fluid too
__________________
Old 04-29-2008, 09:01 PM
4SFEDZ's Avatar
so to be really safe i could get two big coolers and be ok? or would one big one with an electric fan that is temp controlled be good enough. i just need to be able to go in stop in go traffic in 100+ degree heat without any probs!
Old 04-29-2008, 09:35 PM
DeltaT's Avatar
If you run 2, try to set them up in parallel (Y-block to both with hot oil, Y-block back together back to the tranny) instead of serial (out of one into the other). They will shed more heat and have 1/4 the restriction and psi loss.
Jim
Old 04-29-2008, 10:14 PM
hashtagBMW
Speed Density's Avatar
Performabuilt has really good info on their FAQ about running multiple coolers.
FWIW, I just run a single B&M with the stocker bypassed.
Tony.
Old 05-01-2008, 11:27 AM
DeltaT's Avatar
Can you post a link? I just looked at & searched their entire FAQ and there is nothing about multiple coolers except they say to take your radiator cooler out of the circuit when you add an external cooler.
Jim
Old 05-02-2008, 06:03 PM
4SFEDZ's Avatar
Jim
i did to?
