help plz! would like to know of any less expensive stalls!
the cheapest i have seen so far is a Yank!
$575-3000rpm
please tell me i havent looked hard enough. lol??
for a stock 4l60e
$575-3000rpm
for a stock 4l60e
I have an 11" (278 mm) that stalls 2800-3000. It still uses the full size 12" lock up clutch. It will hold 400 rwhp just fine. It is not going to give you the best performance, but it is a nice bump in stall. Tech price is $350.
The problem with some of the smaller 9.5" budget converters is they use a clutch out of a FWD 150 hp car. It will not last and can take a lot with it when it goes. That is why the higher end converters use a billet front, it allows you to use an oversized clutch to hold the extra power. My 9.5" with billet front and billet piston is $700. Let me know if interested.
Chris
Chris
Don't cheap out, man. If you can't afford the one you want right now, save up until you can. Otherwise, you'll end up posting again inside of a year about how your stall took a **** and took your tranny with it.
