Driver's side rear trans sensor leaking Is that the speed sensor? It's a round plastic disc like thing in the side of the transmission near the rear output shaft with a plug in it. I'm can't find a part number or listing for that piece to find a seal or gasket. |
That would be the vss (vehicle speed sensor) |
Thanks. Do you know if it has an o-ring in there? |
There is and oring around the sensor if leaking around it you can replace that , If leaking through the plug you will need a new sensor |
I noticed recently mine has the same leak. I would be interested in finding out what part # the seal or o-ring is and how difficult an operation changing it would be. |
| All times are GMT -5. The time now is 01:09 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
