DTC P0751
Old Sep 2, 2003 | 12:57 PM
White2000TA's Avatar
Default DTC P0751
Hi guys,
I just had 3.73 gear put in on my 2000 transam on friday. I was told to take it easy on the car for about 500-1000 miles, which I have done. This morning I got a SES light with the DTC code of P0751. The PCM had 3 of these in rapid succession. This was not under much acceleration (maybe 10% TP). I looked up the code on Alldata and I get
1-2 Shift Solenoid Valve Performance.
Would this have anything to do with the work that was done on the car last week? I reset the code using autotap, and have not received the message again. Is this anything to worry about?
Thanks,
Mike
Old Sep 2, 2003 | 05:24 PM
Ragtop 99's Avatar
Default Re: DTC P0751
normally those are converter slip related. I'd clear it and see if they don't go away. If you start having shift problems, then consider replacement.
Old Sep 2, 2003 | 10:02 PM
Well the shift from 1st to 2nd is very hard and does jerk alot. I had predator programming to increase the shift firmness and speed until friday. I removed that programming but 1-2 shiftings still seems VERY stiff. I cleared the code and it has not returned.
Old Sep 3, 2003 | 10:54 AM
Just so I got it right can I just replace my stock TC with a new one to solve this problem? If so which one would you guys recommend? I mainly drive this thing for street racing. I do not have drag radials and have 3.73 gears in it at this point. Engine is fairly stock, but I am installing heads/headers/cam and a LS6 intake.
Thanks
Old Sep 4, 2003 | 10:52 AM
Freeze Frame from the PCM when I got the DTC code. This is from today got it again....
Diagnostic trouble code P0751
Module Engine controller ($10)
Description Shift Solenoid A Performance or Stuck Off
Fuel system status bank-1 and bank-2 B1=$02,B2=$02
Calculated load value 7.84 %
Engine coolant temperature 172 °F
Short term fuel trim: bank-1 -4.69 %
Long term fuel trim: bank-1 13.3 %
Short term fuel trim: bank-2 -3.13 %
Long term fuel trim: bank-2 12.5 %
Fuel pressure 0 kPa
Manifold absolute pressure 59 kPa
Engine speed (Revolutions Per Minute) 1309 rpm
Vehicle speed sensor 36.7 mph
Mass air flow 22.7 gm/s
Throttle position 14.5 %
TCC 196
Exhaust gas recirculation valve sensor 2.29 V
Fuel tank pressure 2.06 V
Exhaust gas recirculation valve 44.7 %
Engine coolant startup temperature 27 °C
Desired idle 550 rpm
Injector pulse width cylinder 1 5.52 ms
Injector pulse width cylinder 2 5.60 ms
Desired linear exhaust gas recirculation valve position 43.1 %
Barometric pressure 100 kPa
Commanded air fuel ratio 2 14.6 :1
Engine run time 616 sec
Misfire current status 0
Odometer when first code set since cleared 95 km
Odometer when last code set was cleared 95 km
Freeze frame counter 0
Freeze frame pass counter 0
Freeze frame not run counter 0
Electronic throttle control indicated pedal position 0 counts
Electronic throttle control indicated throttle position 0 %
Percent desired throttle position 0 %
Percent pedal rotation 0 %
Trans output speed 1869 rpm
Current gear 4
Thanks,
Mike
Old Sep 4, 2003 | 07:44 PM
LS1NOVA's Avatar
replace the 1-2 shift solenoid first. They are only about $30.
Old Sep 5, 2003 | 09:30 AM
Thanks guys i will be installing the new solenoid this weekend.
I appreciate the help here.
Old Sep 26, 2003 | 06:44 AM
ok guys got my p0751 again. I replace the shift selenoids about 3 weeks ago. I am getting this car ready for its first drag race over the next few weeks and one of the mods is a 3200 stall converter and flexplate. Will this get rid of the p0751? any other ideas what could be causing this? I cant believe that i have gone through 2 selenoids in 3 weeks.
Thanks,
Mike
