Experienced TIG Welder
Click here
Help Wanted: Wolfe Race Craft is looking for a motivated employee.
Position: TIG Welder
We are looking for an experienced TIG welder to join us. We need someone that has TIG welding Experience and can weld for extended periods of time building and assembling our products. We want someone that is driven to work hard and get the job done, what ever the task that may be.
Experience Required: YES
Must be able to TIG (Heli-arc) weld proficiently. We will not train. Must be able to weld flat plate and tubing. Will be working with 4130 Cromoly Tubing & Plate along with Mild Steel Tubing & Plate. Will be using jigs to assemble items, followed by welding then final assembly of products.
Aluminum and Stainless TIG welding a plus, but not required
MIG (wire feed) welding also a benefit, but will train.
Will also be cutting and notching tubing & plate along with grinding & belt sanding. Will be using Mill, Lathe, Band Saw, Belt Sander, Press Brake, Tubing Bender, along with other machines and tools.
Hours: 8:30am – 5:00pm M-F, Overtime available (required at times) along with some required Saturdays
Pay: Negotiable based on experience
All employees start on a 90 day probationary condition. Will be continually evaluated in terms of quality of work, work ethics & enthusiasm, daily attendance & punctuality, and overall ability to grasp tasks quickly and perform them up to standards. Along with fitting in with other employees and work environment.
Welding Sample (test) will be required to be considered for position. Bring your helmet and gloves if coming in for interview.
Contact: Application will need to be filled out to be considered for position along with welding sample. You can fax to number below.
Dan
817-275-8899
Fax: 817-886-8724
e-mail: techsupport@wolferacecraft.com
Map to Location: Map
Dan
817-275-8899
Fax: 817-886-8724
Originally Posted by MADMAN
Damn after the guys I have had interview you must be expecting GOD to come to work!!! LOL
Just need someone experienced.
