STS Twin CTS-V Kit...
#83
once I get mine I will actually never sell it... I think that I am getting such a great deal that I would be stupid to sell once i get it. Besides! think of all the upgrades that will come out over the next 10 years. A perfect example is the old audi s4's w/ the 2.7L tt's! Audi came out with that shitty 2004 thru 2007-08 N/A 4.2L crap that would cost MORE then the car to upgrade!! Like $25,000 think I even seen it up to 45,000 to upgrade that hunk of junk while the pre 2004's are fast as hell and cheap cheap cheap to upgrade!!! I hope the same thing will happen with the pre 2009 CTS-V's... I also wonder it the drop in price has something to do with the bailout that GM needs?? not sure and really never thought about it!
#87
#89
#91
#92
hey guys, name is Michael... first time posting ....
just had couple questions regarding the sts kit on the cts-v.
interested in purchasing the cts-v twin turbo kit, but would like to know what all is included due to the fact 9k-10k is a lot of money to spend for not knowing specs /names /size / etc /etc....
injectors... if so what pound
upgraded fuel rails or no
boost a pump or just a bigger fuel pump or both
names of turbo and size
intercooler and the spec of that
the plumbing (what type of piping / size of the tubing / pre-bent or not/ weld or bolt on)
mass air (if so what size) or just stock
any need for upgrading oil pump and or water pump
pcm tune ( car is still under warranty would like a system that would keep my stock tune in addition to sts turbo tune so i can switch in and out if needed)
If there's anything else that im forgetting, that is a common upgrade for forced inductions please fill in
#93
a turbo is an exhaust restricter and my be seen as a muffler in some states i believe thats why it is legal.
#94
http://www.ststurbo.com/cts_v
I happened to be on the STS site today and happened to see this. I didn't know if anyone else had seen it yet so here it is. What is a safe PSI # on a stock motor because I would have to bump the PSI up enough to break 500hp to the ground.
#100
okay, i didnt read every post here but here i go....
where is the maf located?
the system is way cleaner than the first stuff sts came out with on their first kits. i do however think that the price is a bit high for the kit since it uses pretty cheap stuff. i would understand if it had higher quality pieces like t-bolt clamps n-such....you would still make a butt load of money even if you didnt skimp on the small stuff....
