Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
How many miles does your V have?
Old 07-28-2016, 09:37 AM
  #161
ls1247's Avatar
Old 07-28-2016, 05:03 PM
  #162
isis's Avatar
Holy ****. I just crossed 50k a couple weeks ago when my outback went in the shop for an ugly job I wanted no part of.
Old 07-28-2016, 05:39 PM
  #163
ls1247's Avatar
That picture would be better if the needle was somewhere over a 100....my bad.
Old 07-28-2016, 07:02 PM
  #164
isis's Avatar
How many of those miles are yours?
Old 07-28-2016, 07:28 PM
  #165
ls1247's Avatar
I bought the car December 2013 with 152 on it.
Old 07-29-2016, 11:33 AM
  #166
BudRacing's Avatar
152k is about when anything with a bearing in it starts to fail. How much have you had to replace?
Old 07-29-2016, 02:41 PM
  #167
ls1247's Avatar
I haven't had any failures but as a gear head, I've done a lot of maintenance...water pump, idlers, starter, alternator, clutch, brake rotors, shocks...
The fuel pump was prime for failure but the recall replaced it before it left me stranded somewhere...
As far as I can tell, the valve covers have never been off it and it's still on the original transmission. It had a 4th gen diff in it when I bought it but I've gone 8.8 since then.
Old 07-29-2016, 02:42 PM
  #168
rand49er's Avatar
About 75,125 here. Needs a thermostat. Probably do it next week.
Old 08-04-2016, 03:48 PM
  #169
greddy91's Avatar
46k here... someone should buy it before it hits 50.
Old 02-07-2017, 01:57 PM
  #170
Niccorazi's Avatar
72k, part of me cringes at that, another part of me is ecstatic that my 10 year old car has only 72k miles!
Old 02-07-2017, 07:41 PM
  #171
jcollege's Avatar
Just rolled 110k
Old 02-08-2017, 08:29 AM
  #172
BaMaDuDe87's Avatar
Just bought an '05 two Sundays ago. 85,640'ish coming into work today.
Old 02-11-2017, 11:22 PM
  #173
daknomad's Avatar
Originally Posted by TheAce
I'm 10 miles to work each day , each way - bumper to bumper with every type of super car imaginable.... all going 30 mph.
you must live in the same city with the same commute as me....... I
mine has 107k
Old 03-28-2017, 10:43 AM
  #174
mmyers024's Avatar
I have 225,000 on my 2005 v. I got it with 220,000 and have done some maintenance since then. I did the alternator (twice because I tried to go cheap the first time), water pump, radiator hoses and Creative Steel motor mounts. The PO had the transmission rebuilt and an LS7 clutch installed along with a Creative Steel short shifter. It runs like a champ and the trans shifts are short and precise with the short shifter. When I got it the motor was seriously rocking back and forth which was horribly bad motor mounts but now it's tight as a drum. The paint is very good but all the emblems are faded badly and the wheels are very curb rashed. The PO drove it 200 miles a day on his daily commute. A long drive but a fun one.
Old 03-28-2017, 12:02 PM
  #175
jmilz28's Avatar
just turned 90k. Bought it Nov 2015 with 65k on it. Lots of proactive maintenance done and ongoing.
Old 03-29-2017, 08:07 AM
  #176
MN_V's Avatar
Up to 138k now on my '06. Getting ready to put another radiator in it, but otherwise everything is doing pretty damn good.
Old 03-29-2017, 01:08 PM
  #177
dmistretta's Avatar
79100. I've had it almost a year, maybe 11 months now. I bought with appx 74000.
I work from my home office and don't drive much. Most of the miles come from either going to car shows/meetups with my father or vacations.
Hoping to keep it low as I intend on keeping it forever.
replace:
- rotors as they all had a big lip that caused squealing.
-revshift bushing for trans mount and shifter rail, and added the modified hurst short shifter.
Still have a bunch of side to side play.
to do:
- I believe my stock flywheel is causing vibrations at 2100rpm and will address it whenever the clutch decides to start acting up. Will be going with LS7 clutch and a lighter flywheel. Not sure if it'll be the 28lb one or 18lb. I'll likely try to address the side play with the roll pin trick I've been reading about.
-have a replacement trunk release switch for the door, mine is spotty
Old 07-12-2019, 07:41 AM
  #178
JEFFCTSVMANW's Avatar
85,600 miles
06 V with Borla Cat back and K&N FIPK
Old 07-15-2019, 10:39 PM
  #179
cam3439's Avatar
Just turned 37k.
Old 07-16-2019, 08:33 AM
  #180
isis's Avatar
3 yrs later - Around 57k now. Been back to DD duty for around 2 years but just don’t go far each day. ~5 miles per day.
Quick Reply: How many miles does your V have?
