Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Any Maggie tech guys around?
Old 03-22-2010, 02:23 PM
z28poweredlt1's Avatar
Default Any Maggie tech guys around?
So I was getting ready to tune the caddy yesterday, noticed that the fuel rails where so hot I could hardly touch them. I'm wondering if there is a way for me to cool these down by insulating the rails somehow. The blower itself is very hot. Can I possibly add another water pump to move the water in the cooling system around a little better?
Also, the maggie kit I have came with 63lb injectors, which on GM's fuel pressure I believe is closer to an 84lb injector? Holy hell thats huge!! Why so big?
Next question, debating on getting in on the kooks GP, curious as to what kind of gains you guys are getting over stock manifolds. I would probably be going the 1 3/4 catted route.
Cheers and thanks.
Old 03-22-2010, 04:56 PM
NeverSatisfied02's Avatar
FI, I would go 1-7/8". You will see huge gains over the stock manifolds with that blower on there. As far as heat, those blowers are known to get very hot! I'm not sure if you can add anything to it to make it cool any faster but that would be a good idea.
What pulley are you running? My buddy had the same blower on his c6 vette and with the small pulley, between heat and spinnin it hard, it didn't last long. Luckily they covered it under warranty. You could throw a 50 shot on it just to keep it cool when ur really runnin it. Prob pick up big power too but you would need colder plugs and a tune for it.
Old 03-22-2010, 05:23 PM
tityrous's Avatar
could you find bigger heat exchanger?
Old 03-22-2010, 05:25 PM
raven154's Avatar
You pick up the maggie new or used? If used, a few guys would run the bigger injectors and ditch the magnavolt. If from magnuson, no clue!
As for the water pump, I have always wondered. Moving the water too quickly wouldn't give the HE time to transfer the energy. To slow, the maggie builds heat. I think it would be beneficial to add a slightly high flowing pump but that is strictly my opinion. I just dont think it moves enough water to really let the HE do its job.
Old 03-22-2010, 05:53 PM
DoctorNick's Avatar
I always wondered about adding a larger coolant tank for the maggie. More fluid to spread the heat thru.
Old 03-22-2010, 06:01 PM
Car was done at magnasun, got atleast 35k+ miles with the charger on it. Still running strong as ****!
tityrous's Avatar
In the cobalt world...... lol people have been running a second HE and bigger coolent tanks too keep the temps down. It works decent until you downsize the pulley and the blower becomes more of a heater then anything.
Old 03-22-2010, 06:10 PM
lubelizard's Avatar
Larger heat exchanger would allow you to run on boost longer before heat soak. It may reduce intake temps if the exchanger isn't large enough, otherwise it may have a negligible effect. Larger injectors over a crutch is almost always a good thing. Isn't the intercooler mounted between the blower and intake? You could add some pipe foam insulation between the rails and blower to reduce heat soak from the blower case. With a supercharger, I think 1 7/8 headers would net you a bit more, and throttle response wouldn't be an issue with the larger headers. From OEM manifolds to headers on your application will net you far more than headers on an n/a application.
Old 03-22-2010, 07:10 PM
Stepside's Avatar
Hmmm, Isn't 42LB injectors, standard issue for the MP112?
63LB injectors?? = overkill Are you sure they are 63LB and not 42LB?
How's your mileage?
Old 03-22-2010, 07:20 PM
deedubb's Avatar
Mine came with the 42#'ers (green tops)....but I know several people out there got 60#'ers with theirs. I'm not sure why the difference though.
Old 03-22-2010, 07:28 PM
How's your mileage?
Yeah they're 63's according to the part number. Mileage could be better, last 2 tanks where 13mpg, driving conservatively and I'm at 15.3mpg currently with an average vehicle speed of 24mph which I think it fair. So I think it would be a decent amount higher on a highway tank.
Double checked magnasun's tune yesterday and everything checks out. Not running rich at all, o2's look brand new!
Old 03-22-2010, 08:02 PM
Thats about right. Mine gets 16-17ish in the city on average and 24-26 on the hwy...
Old 03-29-2010, 12:56 AM
Just an update, got 17.8mpg on the last tank, Probably about 65% highway, the rest was in stop and go.
Hard to go anywhere without traffic here.
Old 03-29-2010, 02:56 PM
1BADCTS's Avatar
What's the stock pulley size for the maggie kit? Mine has a 3"...
Old 03-29-2010, 03:00 PM
raven154's Avatar
The older one was 3. The newer ones were 2.8.
Old 03-29-2010, 05:25 PM
Wonder what sort of a gain I'd get out of a 2.8, and how much it might shorten the lifespan of the engine.
Old 03-30-2010, 09:19 AM
1BADCTS's Avatar
It should only go up about 1 to 1.5 lb... shouldn't hurt anything. I think I'm going to make the swap. My belt is getting frayed and needs to be changed anyways .
