cts-v exhaust manifolds v1 vs lsa
Anyone?
Is the exhaust port different?
I found a few vague references to the lsa manifolds being tighter to block but really do not want to buy another set just to find out they are the same as the ones I have.
They look the same to me.
I'd be interested in anything you find out. I have a friend with an LS2 C6, he put LS7 manifolds and exhaust on it and it really woke things up. Since then I have wondered if LSA manifolds were internally larger and would bolt up to the stock V1 cat-back for a similar improvement without the downsides of headers.
Headers are a good mod, but I don't want them on my Caddy. I'm sure I'm not the only one.
I bought some LSA's and the intent of running them and comparing them. They look similar never got the chance to see the v1's side by side with the LSA's. Long story. Went kooks. Wish me luck with visuals.
Some good pics:
https://houston.craigslist.org/pts/d...409237788.html
versus the ones reckless has in the classifieds now...hard to see a difference.
Do you still have the LSA ones, Doble? Maybe you could coordinate with someone that's got some V1 manifolds to compare? Or maybe post up some measurements (port diameter at the heads, collector outlet diameter)?
I agree with jmilz28, though - looking at a few Ebay ads, it's hard to see any difference.
Good question: because the manifolds and the cats are the biggest restrictions, by a lot. The dual 2.5" system with an X inside the resonator, smooth bends, and dual mufflers doesn't cost power until you hit BIG numbers. High flow cats alone will free up 10-15 at the tire and headers another 20-25, all on a stock re-tuned 243 headed LS engine. A 3" system will not give anything more than single digit gains over stock, if that, until well over 500 at the wheels. Don't get me wrong, I love big exhaust, but on ANY LS motor, headers and tune are your best first mod, and supporting mod for a long time. That said, it's still a fair question, and buying a whole V2 setup and testing it vs. stock would be cool, after you modified the V2 system to work. There's an awesome thread on V2 headers, bet it holds up through the whole system. Still don't think it's as worthwhile as the headers, that's the biggest restriction on our cars from the factory. Only way manifolds may matter is if the internal diameters are bigger, as the tube shapes look identical to my eyeballs. LS7 manifold have intrigued me for a while but after all the labor, I think headers would be better net worth. If they were a bolt on affair like vettes, that would change things.
