Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
DIY Ford 8.8 into V1 Build thread
Old 01-08-2013, 12:09 AM
  #241
punishmentcycle's Avatar
I'm running 3.55's. deff lost some pull in the mid range at higher speeds but I'm getting used to em. Took alot of the spin outta second off the hit
Old 01-08-2013, 12:50 AM
  #242
FuzzyLog1c's Avatar
I said that our drive ratio was too deep because we can't carry enough tire to use it. I disagree that 275mm in the rear is a lot of tire (e.g. D3's 1001HP Le Monstre is running 275/30ZR20 front and 345/25ZR20 rear) and that 12.0-12.5 is "the" optimum gear ratio. It might be for some cars, but your weight, tires, and the usable power band of your motor based on its cam and blower (if applicable) will mandate different drive ratios.
This car was not designed to drag race, and it's obviously not amenable to modifications that would allow it to drag race. The 750 RWHP Mallet CTS-V did 12.40 @ 125 mph. Skydiver's 864 RWHP CTS-V did 11.64 @ 133.68 mph. The fastest ever recorded quarter mile was done by the 440 RWHP CTS-VR, which did 11.11 @ 130 mph (3150 lbs with 275/35ZR18 front and 335/30ZR18 rear tires). As a result, I think that selecting a gear ratio for drag racing is a mistake, because it'll lead you down a path that'll ultimately wind up leaving you unsatisfied, if that's your thing. It'd be interesting to see the demographics on how many 8.8/9" IRS CTS-V owners bought/built them to track and how many built them to drag race.
Watch Skydiver fight traction and gearing below.
Old 01-08-2013, 09:33 AM
  #243
im shooting for mid 11's, ill be in the 650whp range on spray..515ish on boost alone. nt05's on my 20's 275/40/20. and 275/45/18 slicks on stock 18's in the back when i do hit the track this year. my car is heavy so its gonna take some practice and driving to do it but i have faith.
Old 01-08-2013, 09:39 AM
  #244
54inches's Avatar
OK, Fuzzy.
Old 01-08-2013, 10:48 AM
  #245
rwarden90's Avatar
i just want a godamn good diff so i can go hoon it wen i want and not worry bout blowing up which is super embarrassing Isn't that what we all want?
Old 01-08-2013, 11:09 AM
  #246
54inches's Avatar
Yes sir, that is what Gulf and I are trying to do.
I also try to add some insight into certain aspects that I am knowledgeable about. I TRY and present them in a factual manner without influxes of opinion.
I try not to start arguments in this thread, but it looks like I am failing.
Schitzo is giving us some more info via specs and pictures from his findings, so we will be getting a good database in ONE place for the community.
Old 01-12-2013, 05:39 PM
  #247
rwarden90's Avatar
Bump for an update?
Old 01-12-2013, 09:08 PM
  #248
54inches's Avatar
ummmmmm, thought we were out of axle choices and I found a shop in TB that will build anything we need......both of us have been busy......Gulf's Housing is soon to be PC'd...I have cleaned and started tearing down Stone17s Al housing so I can blast it and then paint or PC it.
I need to clean up these brackets and get them to the CAD drafter.
Just too busy.
Old 01-13-2013, 09:24 AM
  #249
Here's my pumpkin before going in... All powdered and blinged out
Old 01-13-2013, 09:36 AM
  #250
Damn phone
Old 01-13-2013, 09:44 AM
  #251
Wtf.. Damn phone won't upload multi pics at once.. Sorry
Old 01-13-2013, 08:33 PM
  #252
54inches's Avatar
Did you add the vertical bracing to the perimeter brackets?
Old 01-13-2013, 09:26 PM
  #253
jmargo's Avatar
Thats the newest revision of bracket from CS
Old 01-13-2013, 09:39 PM
  #254
54inches's Avatar
Gotcha!
And in other news, that's similar to our First version. lol
Old 01-16-2013, 11:55 PM
  #255
serik21's Avatar
any updates?
Old 01-17-2013, 10:43 AM
  #256
54inches's Avatar
nope.
Old 01-17-2013, 04:21 PM
  #257
adanieljohnson1's Avatar
Very cool... Counting the days
Old 01-18-2013, 08:06 AM
  #258
GulfM3's Avatar
The stub axles came in from DSS, they look pretty bullet proof. Nothing changes over from the mustang driveshaft to the CTS-V driveshaft so thats a wash.
I just paid my property taxes, which were a kick in the *****, I'll order a Driveshaft in Feburary.
Old 01-18-2013, 08:18 AM
  #259
I8URSVT's Avatar
Great news about the stubs!
Yea property tax sucks, not looking forward to that this year.
Old 01-18-2013, 09:07 AM
  #260
54inches's Avatar
I have the weekend off so I hopefully can get some **** done.
Quick Reply: DIY Ford 8.8 into V1 Build thread
