Replace that driveshaft bearing!!!
#664
Well, it's all back together nice and neat...and it needs balancing. Not sure if my indexing sucked or if he missed it.
I appreciate the offer, man, but it only vibrates above 40 so I can drive to my mechanic since he's doing the clutch this week anyhow and I'll just get it balanced while it's out. No way I'm taking this shaft apart again, LOL!
FWIW, almost all the clunking is now gone at low speeds. Notably tighter! Pretty sure all that's left is clutch and FW related, it's nominal.
#665
I'm looking for someone who is in the position to try something with their driveshaft. The process requires you to unbolt the part of the driveshaft..
Preferably someone who has our carrier installed on their shaft. Message me if you feel you'd like to give my idea a try.
#669
What do you need unbolted?
I'm playing with other carrier bearings so it'll be tight later on. I have a 2pc design I'm going to test with my old one. I would be happy to Frankenstein further if you want.
-Byron
#670
I want someone to bolt their front driveshaft flange hard mounted to the transmission output.. keeping the flex disc in place but instead of staggering them, bolt them together..so they are solid. Then align the carrier with where it wants to be.. and drive it that way.
#671
#673
#675
I don't have any bearing noise or anything but i have a regular thunking i can feel in the armrest like something is bumping the tunnel over bumps. And now that I've been driving the car more I'm feeling pretty significant vibes over 60 mph that I used to attribute to my shitty hard tires. Could this be the carrier? I'm about done commuting in it since my driver is almost fixed so I'll be crawling under it later this summer. Is it pretty obvious if the carrier is shot even though the bearing isn't noisy? My engine mounts and diff bushing are poly and i have a trans mount insert as well. If the carrier is bad, did i cause it?
Sorry if this has been asked. 34 pages is a lot of noise.
#676
If the rear diff is the problem, try to grab the rear diff and see if that moves when you wiggle it. It should be tight. Mine is tight.
#678
The OE carrier support exhibits a lot of movement under transition of power that shouldn't be there, regardless of the condition of the other bushings fore and aft. I had poly motor mounts, trans mount, front diff bushing, and cradle bushings before I did the carrier mount service. It made a major improvement in driveline feel.
#679
Some updates:
We had a quality issue with our carriers which delayed our last batch, those have been resolved.
We also had issues with a flaky waterjet guy who made our clamp tools, this has been resolved as we were able to source another manufacturer who can provide consistently.
A change has been made to DIY kit, where we no longer are doing the return tool policy. The price is now fixed, and you don't have to worry about getting the tool back on time. It's easier for all parties this way.
Final note: we are fully stocked and ready to service or ship! Thanks for all the support guys!
