Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Makin progress
Old 04-03-2017, 11:55 AM
  #661
FuzzyLog1c's Avatar
Originally Posted by Naf
I just have two, i deleted the post cat o2 sensors on the car and installed the wbo2 there. I did a quick reference and i am readin leaner by .15, which is acceptable for a reference.
So, you have one the driver's side for the tuner and you're using the rear O2 port for your wideband sensor? Nothing on the passenger side?
Old 04-03-2017, 01:09 PM
  #662
Naf
Naf's Avatar
I have one on both sides, behind the cats.
Dual wb from innovate. I could have wired in the analog outputs, but they are comin out in waves rather than fixed properly.
Old 04-06-2017, 01:54 PM
  #663
Naf
Naf's Avatar
Antitheft keeps poppin up on my radio and shuttin off my gauges
Looks like i am goin all in on the 06 harness again, but this time new bcm and 06 full calibration
Buyin an 06 steerin wheel as well so no excuses not to work
Old 04-18-2017, 03:17 AM
  #664
Naf
Naf's Avatar
Everthin is workin as it should. I have the 06 ip harness in and the dash all works and no antitheft issue on the rad.
Reassembly of the dash will take place and i will also remove all my add-on harnesses
Will install new wbo2 sensors and wires then take for a low rpm tune. After i run the engine for a while i will do the top end and move forward...
Old 04-20-2017, 09:32 AM
  #665
Naf
Naf's Avatar
Wbo2 calibrated to 4.9 and everythin is still functionin as it should.
Idle needs a couple hrs of work, but everythin is workin properly.
Old 04-25-2017, 04:23 AM
  #666
Naf
Naf's Avatar
Tweaked the idle parameters and so far she is behavin.
Addin the cross over tune in my fuel tank as my original one is missing.
Am also lookin to install the COW booster for tb. My 102 tb is dreadfully slow on the initial response. Lets see what he brings to the table for my application.
Old 04-25-2017, 04:45 AM
  #667
FuzzyLog1c's Avatar
LOL. All the "Cow Mod" is doing is increasing throttle gain. Can't you just adjust your ETC rate limit (e.g. ETC Tip-In Throttle Rate Limit) in the engine section? Some PCMs don't have that feature.
Old 04-25-2017, 04:55 AM
  #668
Naf
Naf's Avatar
Already 100% ,
Most ppl brick their ecus playin with other tb parameters.
Old 04-26-2017, 07:07 AM
  #669
Naf
Naf's Avatar
I've heard that some people are complaining that they still have half a tank of fuel and they ran out of fuel. I investigated my tank and found that the crossover tube was broken on the fuel pump side so I was not sucking any fuel from the drivers side tank rather only the passenger side tank
in order for you to fix it you're going to need about a meter of flexible fuel hose cut and stick them on there and you're good to go I think it's half inch dia.
Now its time to tune and then dyno for top end results.
Old 04-27-2017, 06:31 AM
  #670
Naf
Naf's Avatar
15 months i have been waitin to do this...
Old 04-27-2017, 07:07 AM
  #671
Anthony Toal's Avatar
looks badass, good work!
Old 04-27-2017, 08:35 AM
  #672
Mercier's Avatar
For the record, we waited too..
Looks sweeeeet.
Old 04-27-2017, 10:01 AM
  #673
Naf
Naf's Avatar
Sunday durin lunch i am goin to try my luck and brave the streets. Hopefully no cops are interested and try and tune her bottom end
Old 04-27-2017, 11:20 AM
  #674
jmilz28's Avatar
Definitely don't want cops tuning her bottom end...
Old 04-27-2017, 02:42 PM
  #675
NIKDSC5's Avatar
Looks sweeeeet.
I could not have said this better myself.
Only thing is, I'm still waiting.
Old 04-27-2017, 03:30 PM
  #676
vroom_vroom's Avatar
Would be cool to run a fuel mat in there
Old 05-01-2017, 11:19 AM
  #677
Naf
Naf's Avatar
Today was a good day I charged up my air condition to 600 g which is roughly a little bit over 1.3 pounds
everything works great I adjusted my injected fuel rate so now at idle and up to 2000 RPM I am +/-2 on my long-term fuel trim
Tomorrow I am going to focus on my maf while in motion. All below 4000rpm. Then after about 500 miles drop the oil change the filter head to the Dyno fix the top end and enjoy it
Old 05-01-2017, 12:49 PM
  #678
rjoffe's Avatar
Naf,
Keep the updates coming, I for one enjoy the progress and evolution of your V over the years!
Ron
Old 05-02-2017, 05:19 AM
  #679
Naf
Naf's Avatar
Originally Posted by rjoffe
Naf,
Ron
Thank you,
made head way today i had my min air flow too high, lowered it and tweaked the ifr.
14.5-15.1afr and 420f egt. Happy enough to drive around tomorro.
Old 05-04-2017, 01:22 AM
  #680
Naf
Naf's Avatar
Quick Reply: Makin progress
