Makin progress
#728
Was invited to the autoworks shpw in kuwait, its like a mini sema here for us. And i took the opertunity to copy the ats-v colors.
Forgot to post here, much easier on fb.
Have a vid with my ti corsa setup, was voted loudest car at show.
Now i am rockin a double x-pipe and v2 mufflers. I can drive it, but need a permit for the sticker kit.
#734
Wow, had to search and dig for this old post...
Latest predicament
I scored a cam from cam motion, what they call the stealthy stroker cam. Should make similar power and be much smoother
I also scored two apexi ats 115mm tailpipe silencers to quiet my girl to below stock.
My oil tank came off as it got damaged. We are shortenin it by 30mm and reclockin the bottom so it clears the cradle.
Pix to follow
Man i hate coated bearings, found all my coatin in my sump...Should not be too scared as there is no metal shavings yet
Latest predicament
Pix to follow
#737
I have been away for a long time, and i think i found the issue for my high egt and normal afr...
My egt sensor is 3/4-7/8 into the pipe instead of 1/3-1/2. Will make adjustments tomorro and see how my current 1400F at idle can drop to a comfy 500F
Got a rear diffuser from Poland, should create a smoother rear appearance.
#740
She is back under the knife. My oil tank is leakin around the welds.
Plus there is too much positive crank pressure. I am redoin the hoses to allow the pressure to escape. Also my trans cooler hoses are all crackin, need to be changed.
Tires are all dried up, waitin on some tires to be available soon.
Fun times... spendin more to keep her alive.
