View Poll Results: Vibration at 2200 RPM with LS6?
None at all
5
45.45%
Some, barely noticable
1
9.09%
Moderate, definitely noticable
5
45.45%
Horrible, paint shaker like
0
0%
Voters: 11. You may not vote on this poll
LS6 vibration at 2200 RPM
Awesome, about the same setup as me. My vibrations got worse when I put in the UMI, so it's good to know yours has zero. I'm just trying to rule obvious things out before I pull the transmission and look for trouble. My monster clutch has about 20k miles on it, I have the 28lb flywheel.
I had none with last setup. Havnt ran the car with the current setup
Last setup
Stock balancer
Ls9r clutch with light aluminum flywheel
8.8 diff two pieces dss drive shaft
I had a slight vibe around 45 mph but it was speed specific not rpm specific
And was due to how my diff was setup.
Cs mounts all around.
Last setup
Stock balancer
When exactly is the vibration happening?
While Driving and/or standing still?
Both.
Clutch in/out?
Both, doesn't matter, always there at that rpm
Only at 2200? or 2200 and above?
Only at between 2100-2300, after that it smooths out. Below that it's barely noticeable. Typical idle vibrations with UMI mounts.
Both.
Clutch in/out?
I also noticed that when it vibrates if I lightly push on the clutch, I can feel the pulses in the clutch pedal. Still seems to engage/disengage and shift OK. I have noticed some difficulty downshifting from 6th to 5th. I have to wait what seems like 2-3 seconds before it will move from 6th o 5th. Up shifting is fine in all gears.
Every LS6 will have this vibration at 2200 RPM if the balancer is bad or has been removed and not reinstalled clocked in the same position.
All the LS6's were spun up on a balance machine and the balancer was drilled before being crated for shipment. Once you **** with the balancer, that OE balance from the factory is gone.
How would you clock an aftermarket balancer? How would you ever replace a balancer? I thought the LS motor was internally balanced and the pulley is really just a damper, nothing to do with balance and would cause vibration if it's bad since it would wobble. Are there any pictures noting the orientation if you had to replace a bad balancer?
Read more: http://www.superchevy.com/features/vemp-0205-chevy-corvette-ls1-ls6/engine-redline.html#ixzz3Y4dPIlY7
Follow us: @SuperChevy on Twitter | SuperChevyMag on Facebook
And that's what I'm saying...once you remove the LS6 balancer you're fucked bc there is no way to get it orientated the way it was from the factory without a keyway, or being very careful and marking, which nobody does.
None whatsoever.
Current setup: Pinned front pulley, Katech LS9 twin-disk clutch kit.
Former setups: Never had any vibration when OEM nor when I had UUC lightweight FW with stock clutch.
"As for LS6 engines, which boast a higher redline and some different reciprocating components than the LS1, they're sent to a separate station for a more specialized balance check. There, each LS6 is fired on natural gas and run for about two minutes on a transducer. If an imbalance is detected, weight is modified at either the harmonic balancer or flywheel. It's an additional step that ensures the LS6 is one of the smoothest engines in the world."
Read more: http://www.superchevy.com/features/v...#ixzz3Y4dPIlY7
Edit: Now I have proof to show my wife that the motor is fucked, need to replace it, hmmm LSX454!
Don't worry... She'll only make you regret it until you file for divorce.
