Low Coolant message
Low Coolant message
So I have been enjoying this car for a while now and it had the radiator replaced already once under CPO warranty but that was a while ago, now she is seeing 140k on the clock.
I poked my head under there and could not see anything from the top that was leaking. I topped the overflow off and went for a drive staying close to home and with a gallon of dex and water in the trunk.
the temp stayed in check but i did lose some coolant. Are there specific spots where the stock radiator/cooling system fails? i am going to put the car up and drop the underbelly cover and get to looking around.
is alradco the only option worth spending money on if it does in fact need a radiator? also will the aftermarket radiators use the stock fan setup?
thanks, Ken
thanks, Ken
I would have to check the service records but likely 50 to 60k. The tanks are plastic but I could not see anything seeping down the sides from the top. I was kinda hoping that the poly mounts would have kept the motor in check to maybe not bust up the radiator lol. Wishful thinking.
121k on my stock radiator. Based on how well this one has done if it were to fail I would just do another OEM. I don't like the big size of the alradco and I believe it weighs a lot more. Not to mention $600. A lot of people like them and I'm sure they're the last radiator the car would ever need.
I have an Alradco in my V because I figured I would upgrade when I was installing a new engine. The fatter radiator definitely makes things more complicated at the front of the engine bay. Yes, the stock fans are used with the Alradco, but it's a very tight fit. The thermostat housing / water neck coming off the water pump actually protrudes into the fan shroud, so the only way to pull the fans is to drain the cooling system and unbolt the thermostat housing. I don't know if there's any way to upgrade the intake tract, because even the stock intake barely fits. I was actually pricing out stock-style radiators just last week because I've been considering ditching the Alradco.
i really need to make good on trying to find a local that'll pop metal end tanks on a stock radiator. that'd make a lifetime product that fits appropriately.
the alradco might be nice, but it's probably overkill for literally everyone that has it. the stock radiator does just fine keeping the car cool.
yeah, of all i have been reading i think that if i find the issues is with the radiator and not a line or water pump or some other BS then another stocker is going in. It will give me time to put my new balancer on and get rid of the wobbly one.
i am not looking to make life harder with an alradco taking up room that is not really there to begin with.
still open to others opinions. is rock auto the place to be for a replacement these days?
looks like it may be the water pump. i am getting a drip drip drip on top of the balancer. i dont know if this is a better situation or not. seems easier to replace a water pump then the radiator.
Mine started leaking recently. I'm at 141k and I believe it's the original rad. Its life may have been prolonged by the 160* t-stat. I'll probably be going with a stock replacement. For now it's a slow leak and I add a quart of water about once a week. When checking to see if it was the water pump I noticed I have a dead mouse curled up under the balancer, haha.
Lol. Yeah, I have to pull the belly cover and make sure the only place leaking is the pump. And try to see if it is the gasket area or the pump itself maybe a weep o.hole or something .
back up to the top with this for any insight. i pulled the under cover and there is coolant coming in steady steady drips forming off the oil pan, the k member under the steering rack. looks like the underside of the hoses on the passenger side of the water pump are wet and also the AC compressor is covered. its just a F*ing mess. i really cant pinpoint anything. At this point i am ruling out the radiator and it looks nice and dry up by the water pump from what i can see. everything is so crammed in there and i cant get a good look at a damn thing.
anyone have anything to contribute before i do what i dont want to and just pay somebody to fix the issue. i am thinking my next step is to rent one of those pumps that go on the radiator and pressurize the system and see whats up. would this pressurize the whole system? or just the radiator? is it me or is the cooling system in these cars complicated?
Loose/bad clamp on one of the hoses coming off the water pump to the heater core? Leak from the thermostat housing?
The cooling system isn't any more complicated than that on my 26-year-old Mustang.
wow thanks. I pressurized the system today with it cold and i think its the hose from the bottom of the radiator to the thermostat. i started to pull it but ran out of day light. i will know more tomorrow.
