harness
harness
Hey all...after almost 3 months with tinkering with this swap and no speedo, abs light/TC light on, and no fuel gauge I was checking my grounds and came across a harness plug disconnected in the pass side fender well next to the battery...my question is: what are those connectors for?
harness
If they are inside the fender they are for the abs. In Between the battery and the engine is the voltage check.
Give me 10 days and i may have a perfect harness you may buy from me. Scored a good one off ebay, but i also have my original harness which has a 5v issue somewhere...
Do that...I checked to make sure those plugs were connected to the right spot..can't confuse them ones grey and ones black...the only thing I can think of on ABS is the bearing itself right rear is what the scanner said..but that fuel guage is gonna bug me..still gotta get it in for fuel harness recall so maybe that'll clear that up..but it works when key is in the on position but as soon as I start the car, it quits working...lol
Thanks for checking that out for me..I had to remove the negative cable from the batt for like a half hour, and when I put it back on all seems good...kinda weird to be honest, I think when I plugged them in that one didn't go in all the way..I made sure it clicked this time...now I gotta check my connection to my oil pressure sensor, low oil pressure now 18psi at idle, and only 30-38 at driving speed...SMDH
