Anyone ever gut their Cats?
I have 158K and think my cats are just getting clogged. Had a bank 1 cat deficiency forever (only code) and am wondering why i don't just knock and scrape out all the honeycomb. Thoughts? Will the comp adjust or is it a huge no no.
In general I have read that a gutted cat will flow pretty much the same as an intact one due to the wonky shape of the now-empty chamber so I would expect no performance gain. Not that this applies to you.
Of course if your situation is a clogged cat, I would certainly try it. Worst case, you replace it, which is your only other option anyway. That said, with that many miles, I strongly advise that you put it up on ramps daily for a week and hit those bolts with PB blaster. And also get some bolt-outs for $40 at lowes because you are going to strip them anyway and need some serious force to get the cats off. I forget how many miles mine had when I took mine off but it was in the neighborhood of 20k and it was a straight up nightmare.
Somebody also said that the car smelled pretty bad with gutted cats.
If you don't want to lay on your back messing with the bolts, call around and find a muffler shop that will work with manifold studs, take it there and have them break it all loose and or replace any that break. $80 well spent.
I had a clogged cat on my E36 m3....just one of the two. Holy ****, the car could not drive worth a ****...felt like I was towing a ******* buldozer. Car could not rev past 3k with the clutch in. I measure it with and exhaust back pressure gauge and that one side was pushing 15psi of back pressure at 2500 rpm.
I got the gauge off ebay....I actually have a brand new one I'd sell (had to order a second as I misplaced thendirsrt in the garage).
