Ls2 swap into my 05 cts v
Your doing what I am doing, except it is a bored and stroked LQ9 block. I would just change out the reluctor wheel, I heard good and bad thing about those converters and its not to hard if your gonna go through the engine and check everything out first, I went with an LS3 top end, it is gonna be NA, dont understand why people say the LQ9s are not good for NA, I understand with the difference in weight, but if your inf or a budget build, it is a great motor. You will need and cam extension harness and knock sensors relocation kit. Or if you fancy enough, it is something you can wire yourself. Also, if you do end up using an LS3 or LS2 top end, the fuel injectors may need adapters, some companies have it to match plugs already but just make sure you look into it. Other than that, it is a simple swap like NAF has said
https://ls1tech.com/forums/generatio...e-options.html
from what I can tell, the LQ9 is a genIII motor and therefore wouldn't require cam and knock sensor relocations or extensions but I don't know this first hand. It would also have the ls6 style reluctor wheel in it wouldn't it?
And if you put ls2 or 3 heads on it, you would have to ditch the ls6 manifold as well as the fuel rail wouldn't you?
Let me know how right or wrong this may be.
Thanks
I've been looking into an LQ9 swap for a DD with 230k+ miles on it and this is what I've come up with so far...
Thanks
Thanks
Here's what I've seen on the motor mounts...
https://ls1tech.com/forums/generatio...-question.html
https://ls1tech.com/forums/cadillac-...-06-cts-v.html
Here's a little LQ9 Gen III info...
https://ls1tech.com/forums/conversio...en-iii-iv.html
The aluminum blocks seem to have all of the motor mount holes whereas the cast iron blocks don't. In other words, any aluminum block should bolt into the V1 but the cast iron blocks will need the plate llinked above.
Just to confirm, the LQ9 should already have the same reluctor wheel as the LS6 as its a GEN III engine.
I just done an LS2 swap in my 05...everything will bolt right on, and use your LS6 intake, if the LS2 is a 24x Crank reluctor you're golden, if it's a 58x you'll need a TRG-002 from Lingenfelter ($250) and you'll either delete the knock sensors and tune them out OR get knock sensor extensions, LS6 sensors are on the Valley cover vs on the side of the block on a LS2
