McLeod RST Clutch in V1, which slave?
Is anyone running this clutch? I have it coming sometime this week. I'm wondering what slave will be needed (I'm assuming the LS7), but wondering if I should order the Tick shim/spacer kit. Would like to know before I put it in and measure and have to wait for them to ship it.
The LS7 is what you need. Someone previously mentioned that the vette guys were having issues w/ pre-load using that slave. I did in fact have pre-load measurements before I installed it. I ended up dissasembling the slave and shaving down the internal plastic sleeve which allowed the slave to compress more allowing for proper spacing. Basically the exact opposite of 'shimming'. It worked flawlessly for a good while now and looked great when I took it out!
If you put a huge shim in you end up having to notch the bell housing and/or trans and it just turns in to a pain in the ***. And yea, it would be a huge shim to essentially make a V slave the same height as a LS7 slave.
On that note, anyone wanna trade me good a factory slave for my LS7 slave? I need a stock one
Totally unrelated. I have a built trans in my car now which actually required me to to BACK to a V-slave and a shim with this clutch. Long story short I have the LS7 slave sitting around and need a V slave for my daily
