Traded in the Goat for a V1
Hey, fellas
Figured I would re-introduce myself on here considering this is where I spend most of my time.
I had a 2004 GTO 6m that I had for around 1 year. I grew to dislike it just because of the daily driving aspects of it. It was an annoyance getting my son in and out of the back. No real creature comforts and all around I just felt like it wasn't a good fit for me.
I had been keeping my eye on v1's that were popping up at the dealers near me and I came across this one.
2006 100k and it looked to be unmolested and in great shape. I went and drove it and fell in love
Traded in the goat and drove it home that night, and never looked back.
Immediately did a muffler delete, and replaced the res with an x-pipe.
Then found a guy selling some brand new eibachs and a K&N intake for really cheap so I picked those up. I plan to modify the K&N so it receives proper cooler air. I also ordered the MM spacers and got all that stuff installed.
I then adjusted the parking brake since it was completely non-functioning.
The second day I had it I noticed water starting pooling up on the passenger mat, I freaked out until I realized that it was just the hose for a/c condensation plugged up. Easy fix.
Next order of business is going to be all the fluids, rear brake pads, and then all the mounts/bushings, followed by some power mods. Headers, cam, tune.
It is my daily driver so I am not going to be doing anything crazy with it. I'd like it to last another 100k so just the typical bolt-ons for me.
Anyways, see ya guys around.
This is such an amazing car. I have a kid so the 4 doors is essential. Plenty of room in the back and the drivers seat is an awesome place to be.
Its raw yet refined if that makes sense. There is definitely a sense that it is sorting things out, but you are still in control.
Compared to the GTO it is so much more smooth in terms of power delivery and just overall driving. Great for road trips and longer drives, yet still very capable for spirited driving.
There are a good amount of creature comforts, but you aren't overwhelmed by the amount of buttons or other tech.
Rides great for daily driving in stock form, and even with eibachs it rides comparatively. It is more firm now but nowhere near uncomfortable.
And let me say this, EEEEEEEEEEEEEEEEEASY to work on
I was expecting to have to take it to the shop for things but so far I have done a good amount of work on it and it is hands down one of the easiest cars I have ever worked on.
I'd easily give it an 8/10
I'd say if you are on the fence, get it! Assuming you haven't test driven one do that first and see how it feels to you.
Power steering flush is complete. It looked like someone squeezed black licorice. Most likely the original fluid.
Tomorrow I am knocking out the trans fluid, coolant flush, and if I can find some gear oil for the rear diff I will do that as well. After that I need to get some new front tires and an alignment.
Then...I can start with the fun stuff.
Here's my crude to-do list I started. I am sure that will continue to grow as the days go by. I also need to create secondary check lists for the header/cam swap.
Short shifter is definitely on the mental list, just forgot to write it down. I haven't really looked into the carrier bearing yet but I will. Thank for the heads up.
I try and research extensively before, and during getting a new car so I can try to eliminate any issues that will end up costing me a lot of money.
I am currently still a student (ASU), so time/money is not something I have a whole lot of until I graduate this December.
I don't like it, I love it.
And I didn't do a whole lot to the goat because most of the stuff was addressed prior to me getting it. However the stuff I did do was much more difficult. I did have other random projects and secondary daily drivers, and worked on friend's cars during that time so I was working on a bunch of things.
pull the carpet back by the gas pedal on the trans tunnel, you;ll see a rubber hose that comes from the hvac through the floor. Lay a towel down and pull that hose off the hvac, water will dump out. Then run some air or something else through the hose to clear it out.
That fixed mine.
That fixed mine.
Make sure you're prepared for anything when you do the headers. There's a good chance one of the exhaust bolts has the head snapped off. I had to pull the head to get at mine (rearmost pass side) and the snowballed into a top-end rebuild (lifters, springs, seals, gaskets, smoothed intake ports with a dremel, and degreased/decrudded EVERYTHING). I'm glad I went through all that for some peace of mind, but a surprise rebuild when all I wanted to do was install headers was not the most welcome. It added another $500 to the project.
Luckily it has been an AZ car for its whole life so there is 0 corrosion. I also do not believe the headers have ever been off so I am crossing my fingers that everything goes smooth.
My theory behind it is motor mounts. Once they fail they allow too much movement in the engine. The engine movement against the rigid exhaust with the added heat cycling over time makes them brittle. The head of the bolt was gone before I ever got there. If the previous owners were meticulous about their motor mount replacements it's possible that the bolts are fine, but if they were left to linger for extended periods there's a good chance of it.
Got some stuff done...
Redline 75w90 in the rear diff
valvoline synthetic atf in the trans
new rear pads
tb cleaning
power steering flush
and installed the cags delete. So damn awesome. Best mod so far.
I gave him a good wash and spray wax today. Looks great
Also, here's an updated to-do/done list.
new rear pads
tb cleaning
