Installing clutch, stuck removing drive shaft
Hi guys,
I am in the process of installing a new clutch on my 05 V and am currently trying to remove the drive shaft. I am curious if the triangular drive shaft end that goes to the transmission has to be pulled apart from the rubber piece or if the rubber piece should come out with the driveshaft. Im including a picture of what i'm referring to.
Yes. The rubber piece can stay on the trans. But if you can't get them out, then it can also come off of the trans. Which is how most do it anyway. So if you're hung up, then why not try something different? Unless you have some particular reason why you don't want the rubber piece to come off of the trans.
that rubber disc has 6 holes for the bolts to go through.. 3 to the drive shaft and 3 to the transmission. Those bolt holes are provided using machined tubes. 3 tubes extend about 1/8" on the driveshaft side and the same on the transmission side. Those 1/8" protrusions seat into recesses on the receiving ends of the driveshaft and transmission flange. They can be quite a pain to separate if you havent had the driveshaft out before. give them some good whacks with a hammer and maybe even a srcew driver to help separate from which ever side they want to the easiest. good luck.
