Heads, cam, and E-force build
#62
#63
Look at pulling the fuse box and relocating in front of the fender liner. I believe that is what the Paxton blower guy did. That should create room on the passenger side. Removing the intake on the driver's side should free up some there. Relocating the battery to the rear should give you a spot for the coolant tank for heat exchangers. Remove the fog lights and the heat exchangers could sit behind that opening (you would likely need some type of mesh to keep rocks from damaging the HEs).
