Overclocked steering wheel...what did i break?
I pulled the steering shaft off during my engine swap, and am pretty sure in the process of putting it back, the steering wheel got turned much more than it should have. Now the left buttons on the steering wheel have no function, and the cruise control, while it powers on, does not set.
My question is what did I break, and what is the potential fix for this?
I read over on the Cadillac forum about a clock spring? But from my understanding we do not have analog clocks on the V's...
Any help is appreciated
Clock spring is located in the steering shaft, it's used to measure the degrees off center that the steering wheel is turned.
Not sure how that's accomplished in the V's. I've only ever taken apart air-cooled vw steering stuff.
The clock spring assembly provides connectivity between the PCM and all steering wheel buttons and sensors.
When you break the clock spring, expect most (if not all) steering wheel functions (including the airbag) to stop working.
Yea pretty sure I broke the clock spring at this point. My airbag service light is on, none of the buttons on the steering wheel work either. I think I heard there was a DIY on how to replace this, is it on this forum or the Cadillac forum?
In plain English simple forms... A clock spring is a spiral/circular ribbon cable that is connecting the steering wheel buttons/airbag to the wiring harness down in the steering column. It allows you to turn the wheel left and right while maintaining connections. I also broke mine this way. I was able to replace mine with a clock spring from eBay for a same year v6, however I did have to move two wires from the broken V unit over to the non V unit. All the wires are the same except the missing ones so it will be obvious which need to be moved. One was a ground and I can't recall what the other was but it was orange lol.
Also the clock spring unit contains the entire steering column harness. And thinking back I may have had to add or splice a ground wire inside the steering wheel itself. From what I'm trying to remember, the ribbon cable was missing one ground tracer, so I spliced into the ground for the cruise or something like that. Once you compare the two you'll see what's missing.
So a question related to the steering wheel clock spring.
I am getting a code for the clutch pedal switch sensor. I replaced the sensor and still am getting the check engine light for it, I came upon a post that an individual was also having clutch pedal switch problems and once they replaced the steering wheel clock spring it fixed it. Does that sound right to you guys? I haven't replaced my clock spring yet
Have a lead on a complete steering column replacement for a trade in parts. As long as everything comes out and goes in straight, is there any calibration or reprogramming that needs to be done for the car to recognize the key and steering wheel orientation?
Get the column if you want,. But just use the harness. Once I had the steering wheel off it literally took me 20minutes to swap the harness. Looked daunting but it wasn't. If I recall correctly the one I got was for an manual I think. I just remember I had to splice a ground in the steering wheel buttons area and swap an orange wire that was obviously missing on the V6 one. Also when you have the standalone clockspring... You'll want it centered. It's basically a round plastic deal with a ribbon cable in it.. I believe it goes like 2.5rotations each way from center. So you'll want it to be centered when you install it. Make sense?
What year?
What year?
