Revs hang between gears
06 V and I have a problem that seems to come and go. When I go through the gears (driving normal) the revs will hold when I let off the throttle to shift, will do that off and on or sometimes after I come to a full stop at a light the RPM,s will hold at about 1500 and slowly drop to idle. Any thoughts? Car is basically stock, magnaflow cat back, K&N intake and a mild tune.
Never thought of that! I'll check that out.. that reminds me of another possibility, my K&N was for a 04-05 and didn't have the vacuum tube in the elbow so I drilled and tapped a fitting to hook it back up, is it maybe to large?
Image Credit: Pirate4x4 Article
The last Pirate Pic is a LS1 engine, isn't there something different to the LS6 in regards to oil steam lines or was it the gas steam line coming from tank?
I closed the upper hole which is showed in the pic with green arrows and it was definitely a oil steam INLET coming from valve covers, not the opposite of it, this pic seemed curios for me...
Greetz
Ron
Greetz
Ron
I'm looking at mine and It has a tube from the passnger valve cover to the throttlebody and one from the intake to below the intake. Should I pull them off withsome plyers and inspect them? Also do these cars have pvc valves anywhere?
Should I just go by a foot of this and replace both of them then? What size do you think the hoses are? Looks like it measures around a quarter inch, the hole inside the hose
Went to advance and got two feet of the 3/8 inch fuel hose, seems to be a good fit, hopefully i can make that bend, cause they didnt have nothing that shape in stock
That's possible. Back when I had my Lingenfelter intake tube (which also lacked a provision for the 06/07 PCV), I sealed the hose barb / intake tube interface with a dab of Permatex Ultra Black. However, don't put all your eggs in that basket--another thing to check is that dirty air PCV breather hose (P/N 12594779) next to the throttle body.
Mine is an LS2, I checked my ltft and it's sitting between 0 and 1 sitting at idle
I can't make that bend without it kinking up, so could i run it longer and go around the harness? I could make that work without kinking, or does it have to be short like that?
Anyways i ordered an oem one from ebay for 7 bucks. What i did might work but im gonna put the oem part on just incase
GM part number 12594779 make sure it is the orange printed one. It's all of $7.99. You most likely paid more for the 3/8" hose than it costs.
The cool thing is that you have half of what you need to run a catch can now, and 3/8" hose is always handy.
-Byron
I will have my guy check that, just seems odd that it comes and goes. Can be fine for months and then start doing it again for a week or so. I did an idle relearn on it yesterday and it is better but still doing it
Mine did this quiet a bit until I unclogged the pcv system and restored it's function.
The U shaped hose running from the valley cover to the intake had an air leak which caused high idle.
I also installed a new clean air hose which had also been leaking. The clean air hose is the one that runs from the air intake tube, to the valve cover.
-Byron
-Byron
-Byron
