A/C Compressor DIY Needed
I have searched this forum, and can't seem to find a DIY for replacing the A/C compressor on a 2004 CTS-V. Mine is cracked and I need to remove and replace, and then I will taken to a shop to vacuum/refill.
Any help would be greatly appreciated!
If it's cracked and all the refrigerant has come out, should be pretty simple. Replace the compressor, orifice, and accumulator. Flush as best you can in case the damn thing came apart internally and put **** throughout the system. Refill according to temp/spec, can get refrigerant at any parts store. Shouldn't be much harder than any other belt driven accessory.
The accumulator is part of the condenser on these cars, which given the fact that the compressor took a dump, probably contaminated/clogged some narrow passages of the condenser anyway--not to mention whatever debris has lodged itself with the fins. It's not overly expensive to replace and will definitely bring the performance of the rebuilt system back to a "like new" status. The old one goes to the recycling bin.
I haven't tackled this system (yet) as a recharge was all I needed to get it back up and running this season. If it leaks down again, I've got dye in it to ID the problem.
Best of luck wrangling that old piece out. I'm not sure if the water pump needs to come off for access, but I'm hoping not.
Mine was blowing cold air, but making a loud noise, so I decided to buy a new one. It should be here mon-Tues of next week, I'll be putting it in myself so I'll let you know how hard or easy it was. Shouldn't be THAT big of a deal, except for clearence issues. I'll take pics.
I may have a compressor and condenser available in the next couple months. I threw the belt two years ago at a track event and had just installed a Ron Davis that was a PITA to get to fit with the intercooler/oil cooler/ PS cooler in the front end. That being said I didn't feel like pulling everything to get the radiator out to get to it, and have gotten used to not having it. Also would kind of like to gain the additional clearance with the condenser out of there.
So I just finished replacing my compressor.... pretty easy job if your mechanically inclined.
I removed..
Radiator/fans/condenser
Heater hoses to waterpump (just for space)
Serpentine belt
Compressor belt
Unplug connector on compressor
Removed the ac hard lines from compressor
Removed 4 bolts holding compressor
Pulled it out
Then reverse everything
I know not much of a write up, but you get the jist of it. It's not rocket science. Took me about 2 hrs start to finish and now I got cold ac with no noise from the compressor.
I removed..
Serpentine belt
Compressor belt
Pulled it out
Worst writeup in history.
Lol, just kidding.
Mine just went out, and I just got the compressor at lunch. I'll be tackling this soon. Thanks boss!
Lol, just kidding.
I removed..
Serpentine belt
Compressor belt
Pulled it out
I removed..
Serpentine belt
Compressor belt
Pulled it out
Lmao!!! I know! . It's just really easy to change, just a little time consuming. I didn't have time to take pics, wanted to finish asap since it's the daily.
I spoke too soon and jinxed myself. A month and a half is as long as that charge lasted and I've got green dye sprayed around the compressor pulley in all directions. Great--another $300 in parts and full refrigerant charge plus pretty much a full dismantling of the front end to get to it. Not to mention the sweaty commutes until I can get to it. I'll be doing this along with the ATI dampener, I suppose. At least I finally got my steering and suspension sorted out... for now.
All of those points are definitely at the forefront of my perspective, however, there are times when I'm faced with a tedious and/or expensive repair (like an AC rebuild paired with dampener replacement) where my time and effort becomes a factor and I think--man, wouldn't it be nice to not have to do this if the costs are roughly the same?
Anybody know what he's talking about?
