Rebuilding the factory driveshaft cv joint
Anyone ever rebuild the rear cv joint on the factory driveshaft. I saw Dorman makes a factory replacement, part number 936-042 but was unable to find any rebuild kits. They do make them for other gm vehicles, but wasn't sure which, if any. Figured I'd check to see if anyone has done this before. My v is relatively stock and just daily driven so I don't need anything heavy duty like the single piece or carbon ones. The center bearing is still good, the only issue is the grease seal failed at the rear and now the bearings chatter.
We have service hundreds of the rear CV joints on these driveshafts. No parts are available specifically for the V. The volkswagon Touareg and porchse cayenne shafts are similar design but not interchangeable. Basically. Regrease it, and figure out which seal is bad. The "front" seal in the rear CV joint which goes between the joint and the boot/cap is metal with a rubber coating.. spray it with plastidip and regrease the joint. If it's the rear seal between joint and inspection plate, OEM is cork.. we've remade these with single layer cardboard like from a 12pack of soda. Easy peasy. ONLY ever use high pressure moly CV grease.
I picked up some moly grease, shown here https://www.walmart.com/ip/CRC-SL314...Wt-Oz/22578996
will this suffice? Or do you have some recommendations
If you already took it/them apart, you are 99% fucked. Each ball must go back in the cage right and the cage must go back together correctly. It must go back together EXACTLY as it came apart, including indexing the shaft, or you must get a new one. When I say exact...I mean exact. If you didn't mark each piece, each ball...**** it all and get a new shaft. Follow those directions - and voodoo's- and voodoo is your best option. Dorman is probably your best second option, or your first if the damn thing is already apart. Third are the ones you mentioned.
That's 1 of the reasons I was asking as far as rebuilds go. Replacing all the internals requires less marking up and matching. That being said, I haven't done anything other than crawl under the car and inspect where the clicking was coming from. I will definitely go the route voodoo mentioned. The 1 thing I am curious on though is if i am able to just dropping the back half to regrease and replace the end cap seal without having to remove the whole driveshaft and exhaust.
You're limited to using used parts..either your own in the joint or a whole other used rear joint.
You have to drop the exhaust to get sufficient access.. you do not need to remove the driveshaft to do this work. If replacing the seal between the cap/boot and CV joint. The front seal, then you need to index the joint to the center spline shaft so you return orientation, then remove the joint to gain access to the seal. That seal usually doesn't go bad, but rather the bolts loosen up and grease comes out.
Well this is exactly my predicament. All 6 bolts weren't even finger tight. None missing thankfully. So if I'm understanding correctly, I can regrease, tighten the bolts back up and be on my merry way
sucks to do everything again, but might as well ask, what are the torque specs supposed to be and, what else do I need to look out for when taking apart that joint? also do I need to take it all the way off the car??
The following users liked this post:
jmilz28 (12-15-2021)
