Need HELP clutch issue
recently purchased a 2005 V sedan. Clutch was slipping with any acceleration. Pulled trans and found that the slave cylinder was rubbing the clutch. I'm thinking he was going for the ls7 clutch swap and didn't use the right slave. I'm looking for a complete clutch kit for this exact car 05 Ctsv with t56. It has about 500hp. Or I would like to know exact slave ,clutch , flywheel to use to convert to ls7. thank you. with part numbers
ACT twins are on sale for a few more weeks.
They have stock. T1S-G02 is the part number.
T1S-G01 or 05 if you want to run the LS7 slave without spacer. G02 comes with a stock slave spacer.
The 01 and 02 are 40 lb assembled. G05 is 46 lbs assembled.
Otherwise order up a LUK kit from Amazon if you really want to keep an LS7 setup.
I can't wait to get my new clutch Installed.
-Byron
-Byron
