My V1 LSA project.
#82
So I started getting the 8.8 ready to go together. A little back story on this dif, I bought it shortly after I got the car because of the weak difs these cars have. It's a 8.8 center section out of a 2011 Explorer I paid 60 bucks for has 3:73 rear gear factory ford traction lok and 31 spines axles all I needed was a Iron Lincoln or aluminium ford cobra case. Well after searching for months a mutual friend of the car group we hang out with said he had a cobra case lying around with new bearings seals and the rear case studed that he wanted to sell, so 120 bucks later I scored a cobra case. So far I am into a 8.8 for 180 bucks, the plan is to put new carbon clutch in the factory carrier and new side bearings.
Case all cleaned up
Case all cleaned up
#87
Haven't done much to this lately so here is a small update. The catch can is mount, rockers are upgraded and a few other small odds and ends are done. I am possibly getting a set of dv8s 8.8 brackets for the rear then I can get the subframe back in the car and get it set on the ground. There isn't really much left to do on the car before I can start tuning it.
I changed the route of the fuel system a little, I was gonna do the dual dw300s but after realizing how much of a pain in the *** it is and would be very over kill for my car I will be running a single walbro with a aeromotive FPR and a ethanol content sensor in the return line.
#89
Also Purchased some Dv8S 8.8 brackets off of hefftone on here. So the rear end of the car will finally be going back together I can't wait.
#94
Got the 8.8 all setup and together, just waiting on my brackets to get them powdercoated and mounted to the rear dif.
Pic of the DV8S brackets I picked up, man I can't wait to get them and get some powder on them.
The weather here is getting a lot better and I have ordered almost everything to finish the car aside from axles (not sure what I am gonna do about this yet) so there will be lots of updates soon.
Thanks for looking!
Thanks for looking!
#97
Slow update:
I am waiting on my front dif bushings as soon as those get here I will pretty much slam the gas tank and rear suspension back in the car. I got the DV8S brackets painted and on the dif. Not a huge fan of red but the rest of my suspension parts and bushings are red so I figured I would make it match.
