Bleed Rear Brakes
Bleed Rear Brakes
Just got done replace the subframe/diff bushings and had to disconnect the rear breaks lines to get the subframe out. Do I need to bleed the front brakes as well? I tried just bleeding the rear brakes but the pedal is still hitting the floor.
You've got air in the ABS modules. You will need a tech 2 (or clone) to cycle the abs module to get a proper bleed:
Something like this:
https://www.autozone.com/repairguide...96b43f80cb40a4
