Squeaking belts
Squeaking belts
I just picked up an 07 v and it's had a belt squeak when cold. I replaced both belts on the car and checked the idler and tension pulleys and they seem fine. Has anybody had this issue with theirs. I hate to throw new tensioners on it without probable cause.
It is quiet as a mouse with belt off. Only really makes noise on accelerating past 3k rpm. Takes a few seconds after letting off to stop making noise. Definitely seems to be on main belt.
I've also had issues with the alternator not charging on sub 30 degree startups until I rev up the motor a bit.
