Radiator Install instructions? - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Old 07-31-2018, 05:17 PM
sod
Default Radiator Install instructions?
I need to replace the radiator in my '05 CTS-V. It is leaking all along the top crimp.
It looks like these instructions are very comprehensive (I'm installing a stock radiator). https://ls1tech.com/forums/cadillac-...ican-made.html
I also found this online.
Any other resources out there that I should be looking at?
Any other parts (hoses, thermostat) that I should be replacing at the same time?
Thanks!
sod is offline
Old 07-31-2018, 06:22 PM
Might as well change the belts if you haven't already
Vcaddy71 is offline
Old 08-01-2018, 11:05 AM
MN_V's Avatar
Remove lower hose to drain it. Remove the hose up top. Remove the AC condenser connections and the 4 bolts that hold it on. Install new rad. fill her up. done
MN_V is offline
Old 08-02-2018, 01:54 PM
sod
Default Good call on the belts
Good call on the belts, thanks!
I'm running a Gatorback belt on my Caprice (9C1).
Does the forum have a favorite belt(s)?
Or any I wanna avoid?
Thanks again!
sod is offline
Old 08-03-2018, 11:47 AM
MN_V's Avatar
ac delco or gates. you can change the belt anytime with the radiator installed
MN_V is offline
Old 08-09-2018, 07:24 PM
Depending on miles. Do the ac belt and the ac tensioner while you are there. At least the lower hose also.
demang is offline
Old 08-10-2018, 12:27 PM
like mentioned the belts can be done easy with the rad in. now if you have a wobbley balancer i would replace it as that needs the rad out and is a common issue.
bigti99a is offline
Old 08-10-2018, 03:35 PM
MN_V's Avatar
AC belt is way easier with the radiator out and is like $10. Mine was well worth replacing at 120k miles.
MN_V is offline
Old 08-31-2018, 02:29 PM
sod
Thanks for all the suggestions.
Does anyone know or know where to find part numbers or links to/for the:
  • tensioners (I assume there are 2?)
  • thermostat
  • balancer
  • APR balancer bolt
  • balancer install tool
Thanks again & have a great weekend!
Sod
sod is offline
Quick Reply: Radiator Install instructions?
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
