Headlight options to retain HID but lose washer nozzles?
Been doing some searching, sounds like the DEPO lights are a good go-to option for an OEM replacement. I may consider this, but in an ideal world, I would be getting a replacement housing, in black, without washer nozzles, and maintaining the factory HIDs. Now, it seems this is generally not an option. However, I am wondering if there is a housing option out there that features a "stock" look but with black housings, that I can just swap my factory HIDs into? Or, am I stuck buying aftermarket ballasts and bulbs and swapping into an aftermarket housing made for the stock CTS?
Thanks.
Thanks.
From what I've seen there are no aftermarket housings that will let you use an OEM HID setup. I'm not sure why you feel the need to keep your OEM HID setup though. As far as I know, all of the aftermarket options are plug and play with the HID temperature of your choice. You really aren't spending any extra for the aftermarket HID's. If you are looking for a stock look with black housing, Spyder has a great option. But if you decide to get something other than stock look, my personal and favorite setup is the dual halo with projector (pick a brand, they all look the same).
Not a fan of the halo look, basically looking for stock but with a black housing. I'm not stuck on having to retain the stock HIDs, it would just be nice. I've only had the car for 3 weeks and so far I like their performance much better than previous drop-in HID's i have had experience with in factory and aftermarket projectors. Its been a number of years, I'm sure technology and quality is getting better... But, my housings are pretty trashed, and they need to be replaced. So, if going the route of an aftermarket housing and an aftermarket HID kit is the best way to go without spending the better part of $1k, I'll go that route. I'm in Canada and the exchange rate hurts right now buying from the states!
Just solved that problem myself
The cheapest oem hid option I found was Fleabay for ~700 a pair. They did not have ballasts with them for that price and only cheap bulbs.
The reasearch I did told me I was going to be happier with an oem style halogen setup with the correct 6k led bulbs. All the bulbs from Hikari and the headlights set me back 259 delivered from amazon.
I’ll have the lights tomorrow but it will be a couple weeks before I get them in the car. My oem lenses were past buffing so time to replace. Front end just got repainted and didn’t want nasty lights on such a pretty girl.
Amazon aftermarket Cts halogen assemblies
My factory lenses have cracks in both, one let's in moisture enough to be a pain. I've never liked the grey housings so it's sounding like I'll be looking at an aftermarket black housing with aftermarket HIDs. I'm not against the LED options either. Any recommendations for a good HID bulb/ballast?
