Canadian Members We never leave because we have The Beer Store
First Friday Night at TMSP Tonight
Old 05-06-2016, 06:43 AM
transamtom's Avatar
Default First Friday Night at TMSP Tonight
Friday night action kicks off tonight at 7pm gates open at 6pm.
$30.00 T&T
Old 05-07-2016, 12:44 PM
manzo81maro's Avatar
I was there, good turn-out!
Old 05-07-2016, 08:12 PM
transamtom's Avatar
How did you run?
I couldn't make it some family stuff came up.
Old 05-19-2016, 08:17 AM
Originally Posted by transamtom
How did you run?
12.0 @ 121mph 2.02 60'
Can't wait to get a good rear and some slicks on this thing so I can actually launch it!
PM me next time you plan on going
Old 05-20-2016, 08:18 AM
WS6wanted's Avatar
Sweet video man, your car moves! What tires are you using right now? And are you on a 3.90 10 bolt right now?
Old 05-20-2016, 12:36 PM
Thanks man, I love how it runs! Can't wait to see what it does with a good 60'
Rear tires are 275/40/17 TOYO TQ PROXES drag radials
Yes stock 10-bolt with 3.90 gear
Old 05-20-2016, 04:42 PM
transamtom's Avatar
You have enough MPH to get that thing in the 10's with a decent 60ft.
Find yourself a 9" and then you can let her rip.
Old 05-22-2016, 08:28 PM
Z28 MeTaL HeAd's Avatar
Manzo, I was at the track that night and watched your runs. Sucks the time clocks were turned off/not working and they werent really announcing times most of the night over the PA either.
I loved your car and you definitely no how to bang a gear. Me and my buddy both noticed how soft you launched it especially when you nailed it at the 60' mark and the car spun and took off like a laser beam haha..i told my friend you probably still had a 10 bolt
Old 05-24-2016, 11:29 PM
Thanks! Yea the car is definitely held back by that 10-bolt and Toyo DRs...I'm sure a better driver could ride that clutch just enough to get that 60' down a tad and break into 11's, but I'm still happy with the mph it runs...I know she's capable of lower 11's with a good launch, so I'll get a 9" with 4.11's in there and a good tire setup, and head back to smash 11's
Also need to open up exhaust a little more...trying to move all that air through a single 3" just seems to be a choking point now...gonna go with a 4" Y-merge into a 4" cutout hopefully for about 10 more ponies at the wheels....might go for 1-7/8" headers as well...never ends $$$$
Old 05-25-2016, 03:18 PM
transamtom's Avatar
Got my new Mickey T Drag Radials today so I will be out Friday night.
I discovered my old ones were through the steel belt and into the cord.
I still made one lame 12.8 at 108 pass with no burn out on Monday and still got a 1.93 60ftwalking her out easy
They say this new generation Street SS with R2 compound is better with little or no burn out.
Old 05-25-2016, 11:10 PM
Nice! Yea I'll most likely go with a pair of those MT S/S to replace the Toyo TQs when they're due
Let me know how they do
Old 05-26-2016, 09:52 AM
transamtom's Avatar
Yes I will post up.
I am very curious myself as they have their new R2 compound rubber..
They say little to no burnout required so I will air them to 25psi and go to the line.
They(MT) also say 17psi minimum and that you should try to run as much air pressure as you can.
I will adjust by 1psi until I get my best 60ft,if I pull off a 1.65 or better on the first pass my adjustments might be minimal.
Old 05-27-2016, 10:54 PM
transamtom's Avatar
No burnout and 25 psi got me a 1.90 60 ft.
A light burnout and 25 psi got me a 1.83 to 1.86
A heavier burnout and 21 psi got me a 1.80 then a 1.77 60ft.
So if your willing to settle for a shitty 60ft no burnout is fine.
I still want to try 17 or 18 psi.
The DA sucked it started at 2350 ft at 7pm when I made my first pass and improved to 1725 at 10pm when I made my last pass.
Ran a best of 12.692 at 107.61 with a 1.777 60ft
Worst pass was a 12.827 at 107.67 on a 1.899 60ft that was my first pass right off the street.
A whole bunch of 12.7X's in between.
Corrected to sea level would be 12.3 to 12.4 at 110mph
I need 40hp or a 400lb weight reduction if I am ever going to run an 11 as a bolt on car.
Old 05-29-2016, 11:45 AM
WS6wanted's Avatar
Maybe Arun can tune you some extra ponies? 1.7s are a solid base line, you'll beat that 60 next week. It's interesting to see your comparisons, keep them coming.
Old 05-29-2016, 03:29 PM
transamtom's Avatar
I think its a little rich,but slight rich is safe and Frosts tune for the TQ converter is spot on it runs and drives nice.
Need some cool fall air to blow in every other weekend
Old 05-29-2016, 03:46 PM
dean85gt's Avatar
I've got a pair of the 275/40/17 ET street SS.
Managed a 1.5 60' on 18.5psi in them. Leaving on no boost. They actually hold pretty good. I had luck with a very small burnout (see vid).
This was a few weeks ago in indy. That track was prepped nice....TMP never seems to be prepped well.
http://vid5.photobucket.com/albums/y...psrvwbpx3m.mp4
Old 05-29-2016, 04:32 PM
transamtom's Avatar
I wish I had them on Monday the starting line was good after the weekend event.
Nice run BTW.
Old 06-03-2016, 12:05 PM
Nice runs! Sounds like they do alright
My Toyo's are gettin down there, so they'll be swapped for those MT soon...
Just in the process of ordering a MWC 9", the day after I get a quote, #7 cyl breaks a rocker arm yella terra ultralite, apparently a common issue??? happened at 1500-2000rpm cruising
Hopefully just swap in a new arm and good to go, don't wanna have to dig down to the lifter...but now I'm worried the rest will fail sooner or later...chattin with Tony Mamo to see what to do from here.
Old 06-06-2016, 03:05 PM
transamtom's Avatar
That sucks that you broke a rocker.
I sent you a PM
Quick Reply: First Friday Night at TMSP Tonight
