ABS Issue
ABS Issue
I have a 1999 Z28 modified cam,headers,heads,intake etc...
my issue is when it is cold I have a "service engine" light and an ABS warning light. When driven the ABS is not working.
Once it is fully warmed up lights go away and ABS comes back.
I've had it scanned and you guessed it ... no codes! Any ideas out there?
I had a similar issue a couple years ago. Disconnect your 2 front and central rear connections and give them a cleaning with electrical cleaner (spray). I have 3 channel abs..if you have 4 channel, clean all 4 sensors to start with.
It is a small pain in the ars, but see if it helps. Before you reconnect your plugs, ensure the spray has evaporated and go from there.
Should you still have problems, email back.
