Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Fastest list!
Old 09-21-2010, 08:15 AM
burgers's Avatar
Default Fastest list!
Lets start a fastest list for the carb section. This way we can find out what works and what doesn't. I'll start 9.44@143mph 1.31 60ft, proform 1050 carb, LSX440, Gm LS7 stage 3 Cam, Vic jr L92 Manifold, TX Speed cnc'd L92's, 150 shot.The car is 83 Olds Cutlass with Th400 w/5000 stall redneck converter, 3.89 gear, race weight 3250. Car also ran 9.95@135mph 1.39 60ft N/A.
Old 09-21-2010, 11:12 AM
In-Zane Moderator
ZONES89RS's Avatar
We are going to have to refine the list more, vehicle, weight, trans/stall and gearing.
-Z
Old 09-21-2010, 12:49 PM
LS_10's Avatar
Engine size to maybe??
Old 09-21-2010, 06:18 PM
In-Zane Moderator
ZONES89RS's Avatar
Exactly, but he posted that already.
Old 09-21-2010, 07:27 PM
3pedals's Avatar
Not exactly the fastest, but I am impressed with the little 364, and I know theres more in it with further tuning.
11.39 @ 120, 1.68 60ft
6.0 LY6 27K miles,stock long block, heads never removed
- 227/235 .613/.621 114+4 comp cam, patriot extreme dual springs
-vvt removed by useing ls2 top cam gear
- 850 mighty Demon carb
- vic jr l92 intake
- MSD 6012 36* total timing
- Edelbrock 1 3/4" - 1 7/8" step headers
67 camaro
3234lbs + me(185)
- Ram sintered iron slipper clutch
- TKO600 trans
- 4.56 gears - spool
- 295/55/15 M/T drag radials
Old 09-21-2010, 08:25 PM
retro1977's Avatar
I think Burger got the right idea. Alot of questions people have has to do withsetups cams etc..
Old 09-22-2010, 07:11 AM
In-Zane Moderator
ZONES89RS's Avatar
Exactly, full engine detail with the application it used to make the numbers.
Old 09-22-2010, 09:40 PM
retro1977's Avatar
Burger how about some of the combo's you have run or your customers
Old 09-23-2010, 03:29 PM
DMMizell's Avatar
DMMizell 9.43@145.33 "90 Stang(346 LS);TH350:Ultimate7200 stall,All Pro, CamMotion Solid,2830LBS,9/11/10
This is N/A at 2320 DA.....
Dave
Old 09-23-2010, 09:26 PM
burgers's Avatar
Right now we have a 100% stock 6.0 with 317 heads and gm 1721 cam running 11.90 @ 113mph in a 1979 olds cutlass. Car with driver is 2925#, has a Th350 w/ fuddle 3500
converter, ford 9" w/3.89 gear. Manifold is a vic jr, holley 850 double pumper and electronics are msd 6010 with max timing at 33 degrees. Exhaust is open pacesetter 98-02 f-body headers.
Old 09-23-2010, 09:32 PM
burgers's Avatar
We have another customer that has a 6.0 with stock L92's, vic jr manifold, gm 1721 cam, pacesetters, th350 with redneck 4500 stall converter running 11.92 @ 113mph in a 1984 Olds Cutlass that weighs around 3450 with driver. This car has been running a 750cfm double pumper and needs to step up to a 850cfm carb to get full benefits of the motor. We have a LS hot cam coming for him and I will post up results of the cam swap and bigger carb.
Old 09-23-2010, 09:36 PM
burgers's Avatar
I just got back from Lubbock Tx, picking up a set of Tx Speeds LS7 285cc heads for my car. I also have a PI/Mast 2 piece manifold that is being overnighted for this weekend! Trying to get 4 cars ready for the shoot out.
Old 09-25-2010, 03:02 AM
hotrodscrap's Avatar
3pedals, nice launch! Anyone else gonna post up?
-SS
Old 10-06-2010, 03:26 PM
LSJM1's Avatar
I would see some one with a cam only carbed motor spraying 150-200 shot go as fast as a few of the fuel injected guys like Noyzee
Old 10-06-2010, 03:32 PM
In-Zane Moderator
ZONES89RS's Avatar
How about 9s all motor with a stock long block components and unported heads?
https://ls1tech.com/forums/single-di...-only-fox.html
Old 10-06-2010, 03:42 PM
DMMizell's Avatar
have you seen this list?
https://ls1tech.com/forums/drag-raci...ck-ci-h-c.html
My stock cube (346) is faster than Noyzee with no nitrous....
9.43 at 145 thus far...
Dave
Old 10-07-2010, 07:56 AM
8 second mod
Noyzee's Avatar
you guys are 600 pounds lighter then me with cars set up to run on motor. a converter swap, cam swap and 600 pounds out of my car and im sure i would net some fast times.
your cars go good, dont get me wrong, but far from apples to apples
Old 10-07-2010, 07:57 AM
8 second mod
Noyzee's Avatar
Dave
ps, i wouldnt say 9.43 is faster then 9.39. the 145 mph maybe. lol
Old 10-07-2010, 10:25 AM
DMMizell's Avatar
I said faster.....not quicker, just yet
Old 10-07-2010, 02:20 PM
8 second mod
Noyzee's Avatar
man, your gonna make me spend money on my car now and loose some weight, now converter, new cam and get rid of my stock heads. see if i can keep up. lol
Quick Reply: Fastest list!
