lq4 with ls3 heads.what ignition?
i have a lq4 and wanna go carb i already have a demon and holley carbs.i need to know what intake to run and how much?also do i need to keep any sensor or sensors from my lq4 motor?what ignition do i need to run with my set up?its going in my 67 camaro will there be clearance issuse?thanks
I have a carbed 5.3 in my 67 firebird. As far as clearance goes, it's a tight squeeze, but it should work. I have a dropped 3" air cleaner on mine with no problems so far.
You need to keep some sensors, ie. map, cam, crank to use with the 6010 box. Give the manual a quick read and you should be able to figure it out.
60, carburater, carburet, carbureted, controller, heads, ignition, intake, lq4, ls1, ls3, msd, sic7camaro, tunning, whats
