Whos runnin the Super victor
In process of a build and ready to order my intake
I see alot of people using the Vic Jr but wondering
If the super Vic would be better..cam is most likely eps single plane or custom pat g..
Are you at least happy.if you don't mind me askin what's your motor set up. I'm building a 383 cam with stock heads for now going in a fox with a turbo 350 and a 373 gear. Now just doing research for intake. Cam.and stall
Thanks to all for the replys.. I should be spinning to at least 7k. Not to sure how big the gear will get tho while I'm planning on running a shot.. A couple of my efi buddies say that the jr sucks but that's on the efi manifold.
Thanks again
Thanks again
I am running a vic jr on my current motor and it supports my 605hp to the wheels. It's a stock bottom end 6.0L with TEA ported 853 heads and a 228r cam with a 200 shot. My next motor will have a super vic.
Got a super vic on my combo
Iron block. With 2007 ls2 rods pistons
853 heads minor port on intake and exh. No chamber work. Not milled
Comp cams shelf cam. 54-448-11. 238/240. .605/.609 112lsa
830 Holley HP carb 1" spacer for vac port. For brakes n tranny
4l60. Full man. Yank 4000 stall unlocked
Kooks 1 3/4 LT's. Into 3" true duals. 1 chamber flows. No x or h pipe
423/373 This is using a MSD curve pill 1. I just wanted an idea
I had a stock carbed LS2 in a 3100lb. Mustang,and took my Vic jr, and swapped my buddies Super victor on for giggles,and the car went 3 tenths & 5mph faster. needless to say he never got his intake back.... I bought him a new one....
did you do this on the same track/day? if not, please go back and look at what the DA was on both days, so we can get a true assessment of the actual gains. cause if you made the pass with the vic jr on a hot greasy day with marginal traction and the pass with the super vic in negative DA conditions with 100% traction then it's not a great comparison test. thanks
