L92 heads+Trex=?
But, the 5.3 heads i should be buying soon....i dont know if i will have PTV issues with them, i know they have a smaller chamber and the fact that the compression will help allot but man, i i just dont know if the valves sit lower than the 317s or not, i have been told the 243/799 casting would be the same as my 317s and need no PTV clearance, but the 5.3 TEA heads, i really would not want to have to clearance the piston for the valves if i dont have to, they have 2.02 valves, and that would be near the limitation if they are unmilled, i had .110 with my .030 milled 317s, i will have to check anyway when i do the swap, but it would **** me off no to be able to just put my **** back together.
Old School Heavy
There are many variables here. So, as unappealing as this answer is, the only sure fire way is to bolt em' on and check the actual clearances.
Well, one said they his machine shop told him that anything above 228 duration would probably require cutting, but then again, i am sure this was probably a FT LS1, not a dish piston motor, so really, that is the issue for me, i know the only way to tell is to bolt them down and check, but that is a turn off if i can get away with 243/799s that are ported and not have to fly cut.
The dished LQ4 pistons give at best 10/1 with milled L92's.
With a carb and single plane and enough duration and lift to make power up around 6800-7000 you need an early ICL like 106.
If this causes you to have PTV issues then make the clearance!
I went 137-138 mph at 2900 lbs with an LQ4 and stock unported l92's with 9.8/1 on pump gas.
The Rapid Motorsports dominator 2X required flycutting for intake clearance.
It was well worth the effort..This engine is still going strong in a '57 Vette.
Running 9's on 93 pump, shifting at 7000.
Put the right cam in, make the clearance and don't look back.
Dave
Dave
#32
#33
Of course the new smaller 346 runs better....
http://www.youtube.com/watch?v=bqSf4FDf8MU
again, pick the right cam timing events, and if this causes clearance issues,
make the needed clearance... it will be worth it!
#34
#36
I am worrying that spraying a motor with stock pistons that are fly cut might cause an issue and damage/burn through the piston, seems it would be a weak spot...
What is the thickest head gasket i can find? The TEA heads are already .01 less with the 2.02 valves, but i cannot seem to find out how low the valve is to get a better idea, if i can use a ticker gasket and my dish pistons help me get away with it, that would be sweet. Otherwise, i dont have the monster L92 intake valves, LOL. Sticking wit the Trex.
#37
Dave
Dave
#40
Dave
Dave
i personally would go with milled/worked 243/799 to raise scr/dcr as much as possible for use with the trex cam and still run 93.
similar higher scr trex cathedral port heads combos have worked well for me in the past on pump gas.
running any kind of cam without valve relives makes me nervous. i just cut them in any build now and keep use the thinnest compressed gasket i can find. usually the ls2 .053 compressed gasket.
i shoot for a .035-.040 quench area. most oe ls are around .008-.010 out the bore stock
