Edelbrock carb cam?
Edelbrock carb cam?
Edelbrock offers 2 carb'd LS cams mathed to their intake packages, I was thinking of picking up the 2216, anyone try one already?
CAMSHAFT: Performer RPM Hydraulic Roller
CATALOG #: 2215 & 2216
ENGINE: Chevrolet LS1 V8
RPM RANGE: 1500-6500
CAUTION: These camshafts are designed to be used in engine
swap applications using a CARBURETOR ONLY. They are not
intended to be used in factory EFI-equipped LS1 vehicles.
CATALOG #2215 (12” Hg Vacuum @ 1000 RPM):
Duration at 0.006" Lift: Intake 300° Exhaust 300°
Duration at 0.050" Lift: Intake 220° Exhaust 220°
Lift at Cam: Intake 0.300" Exhaust 0.300"
Lift at Valve: Intake 0.510" Exhaust 0.510"
Centerlines: Lobe Separation: 111° Intake CL: 108°
Timing at 0.050" Lift: Open Close
Intake: 2° BTDC 38° ABDC
Exhaust: 44° BBDC 4° BTDC
CATALOG #2216 (10” Hg Vacuum @ 1000 RPM):
Duration at 0.006" Lift: Intake 314° Exhaust 322°
Duration at 0.050" Lift: Intake 230° Exhaust 237°
Lift at Cam: Intake 0.318" Exhaust 0.318"
Lift at Valve: Intake 0.540" Exhaust 0.540"
Centerlines: Lobe Separation: 110° Intake CL: 106°
Intake: 9°BTDC 41°ABDC
Exhaust: 52°BBDC 5°ATDC
I am looking for low end/ mid range and to keep my stock valvetrain which this seems like it would be easy on. Mainly due to the low lift, but I could upgrade to higher ratio rockers if I wanted to step it up in the future. Not to mention with my Edelbrock discount its only about $275
Good post. Ive been thinking about which cam to run when I get my engine ready for my 67 Camaro if I go the LS route. The 2216 looks better as far as duration goes. Have you done any research on hp numbers with people using the MS3 cam in carbed' setups? I know that cam sounds even more wicked on a carbed' engine. Sounds like your just trying to keep it simple and matched though...smart move.
What makes them carburator only cams?
The 220 cam looks a lot like the LS hot cam, but with matched intake/exhaust durations.
The second cam looks just like the LS Stage 2 cam
Old School Heavy
I really considered the 2215 for my build. However I decided on the Comp XR275 because it had more lift. Another thing to note about the Edelbrock cam is the intake centerline. The 2215 has an intake centerline of 108 degrees compared to many cams of that size that have an intake centerline of 110. This will move the powerband lower and limit the rpm a little.
The 2216 has an intake centerline of 106 degrees which is reminiscent of the old small block Chevy circle track cams. This will also move the powerband down.
Most of the LS cams tend to have less advance than the old SBC style Edelbrock cams. I am quite curious to see how they would perform comparative to the Comp cams of similar duration.
Speedtigger I think you are meaning lobe displacement angle. Intake centerline is about how a cam is degreed in when installed in a motor. Lobe displacement is fixed, the smaller the # the more overlap. Edelbrock cams are kinda ok . There are much better out there. Edelbrock says "carb only" because you need a tune for then to run with fuel injection. From reading your previous posts I know you understand this.
Aleck
Aleck
Old School Heavy
Aleck
Aleck
Be nice if HotRod or Car craft did a comparison between F.I.cams vs Carb'd cams using the same intakes? I had Futral Grind my cam cause at the time no one offered a off the shelf cam for carb'd LS's
My buddy put the 2216 in his 6.0L and I believe he likes it a lot and is real happy with it. He said he saw an article where they made 480HP(not sure if at the crank or the wheels) with that cam. It sounds good, but he hasn't run it at the track or anything. It's more of a cruiser type truck and it gets driven long distances.
This winter I am swapping 243 heads (Z06) and the 2216 cam into my LQ4. As mentioned above I am running the dual plane. I plan on getting it tuned and dyno'd this spring and will definetly post the graphs from that.
I agree, for the time being that low lift is great for my stock LS6 valvetrain, but if I want more power (who doesnt) a future upgrade could be some 1.8 rockers, new springs and pushrods.
