wiring a RPM accessory to MSD 6012 not sure if this is the right place or not but I had an idea for my project. Is there a way to wire something to come on at 1800 RPMs? on my boat i want to wire a water valve solenoid that will let water into the headers at 1800 rpms. kinda like a NOS switch i guess. Is this possible? |
A window switch is designed for anything, not just nitrous, so that would be my vote. |
I'm thinking an rpm activated switch that comes on automatically at a given rpm everytime and shuts off under that rpm no matter what |
Not through the MSD 6012/10 box, you'll need a dedicated RPM or window switch as noted. |
Sort of like a shift light. |
A window switch, that is whats needed. |
forgive my ignorance wiring is definately not my strong suit. But are you guys refereing to a momentary switch like for a power window? |
No, a window switch is setup to activate or deactivate a accessory from a given "window" of RPM you wish to start and end. |
Hahaha that makes way more sense!!! Is that activated by the tach or by the crank? |
Usually by the tach signal. |
Here's a couple examples, first the old-style (uses pills to set), and now the new digital style. Let your wallet be your guide... |
© 2024 MH Sub I, LLC dba Internet Brands
