What thermostat are you running in your carbed LS swap
I dont remember ever seeing a thread on this, so here it goes. What thermostat is everybody running in thier carbed LS. Hopefully this will serve as a good point of reference for people in the future looking for this information.
I am planing on running a 160 degree, but am wondering if my car would benefit from running at a warmer operating temperature. Whats everyone running. Thanks, Eric L
That was kind of my line of thought. My LT1 Camaro SS runs a 160 thermostat. Even though I only drive the car during warm months, when its cold at night in the fall and spring, it barely gets up to operating temp. Where is a good place to pickup a factory 186 degree thermostat for the early style w/p with the 1 piece t stat and housing? Thanks, Eric L
I got mine at the local auto parts store.
We run it with a 16" spal fan and a spal controler most of the time is on low unless the AC is on then another 11" fan will come on. Highest we have ever seen is 200 with the AC on max in 100 degree traffic in INDY for power tour.
I would run the hotter stat. In my car I have a 160 and have the fans set to come on at 185 with the spal controler and they are on low most of the time. I have a remote pump so I want it to open so I can get the water thur the motor at a lower temp.
Tim
Tim
Im running a stock w/p on mine with PLENTY of open engine compartment area and a very efficent radiator and fan. Looks like ill be going with a stock thermostat. Any idea with this setup and a stock w/p what operating temps to look for. Thanks for all the suggestions. Eric L
I've been told that the colder you run an LS the more power it makes. I'm running a 160° on a street only car. I have the fans set to turn on above that, so I am generally running a bit hotter.
Oil condensation on a race motor shouldn't be an issue given how often racers should be changing their oil. Mobil 1 says to change the oil every so many miles or 6 months.
All depends on how the engine is built.
With a alum block and tighter main clearance you need to get the engine and oil up to temp for the clearances to open up correctly.
If you are going to run it cold it needs to be built loose but not ran hot.
The alum block is going to put more condensation in the oil. It the the heating and cooling that puts the water in the crank case. only way to get it out is to cook it out with oil temp. Changing the oil will only remove some of it.
Tim .
Tim .
I couldn't find a decent pic, but mine's the early style that needs to be disassembled. I use a pair of waterpump pliers and twist the guts 90° to get it out. You'll see where the shaft has a pilot that goes into a receiver hole in the housing. I added a pair of 3/16" pop-rivet washers on the end of the pilot to space it away from the housing, and ended up at 170°.
The water is not sitting in the oil it is on every part of the engine that oil touches. The underside of my valve covers are milky untill the oil and engine temps get up to cook the water out. Even in the summer there is some evidence.
My wifes VW was like this in the winter unless we drove it for over a hour.
Changing the oil did nothing to help it. Normal per VW.
Alum blocks need are a different animal and have some goofy things about them.
Tim
Tim
