Whos using F body accessories with alt and water pump only
A while back, Tireburnin posted up his Advanced Induction built 416 LS3 that is running a stock F-body alternator, alternator bracket and waterpump.
See how IF the bolt was in the bottom alternator bracket it would hit, how are you guys getting around this.
Thanks
shouldnt be too tough, unless the bracket is really thin and you arent able to cut it down much?? Hard to tell from the pics
That part sticking out of the unbolted hole is the sleeve. I agree with Barrett, I would grind it flush and either use a thin headed bolt or just grind the head down. I would think that would work. Hope this helps, Eric L
That is the fix I have seen on a couple of different boards
If you're running truck acc with the wp and alt only + tensioner, you'll prolly need same thing as I have which is 725k6(72.5inches 6 rib). I got it at autozone.
