Rear pump squirters leakin while shut off (hot)
Hey guys. Had problems starting after my lq4 after it was warmed up. Couldnt figure it out. Switched base timing all around and all.
So the other day I pull into the garage after driving it a while and I noticed the rear pump squirter squirting fuel. Or percolating fuel. Mind you the truck was shut off. The fuel level looks fine. What else should I check? Is the fuel boiling?
