With that many cubes I would run a set of L92 cylinder heads. That many cubic inches would love the larger runner of those heads. Eric L
I agree. And, with 400" motor you could run an off the shelf cam. The bigger motor will do fine with a 112LSA cam. I would pick a mid 230s @ .050" on the intake and mid 240s @ .050" on the exhaust. It will be a beast.
Depends on what piston your running? And what compression your running. Large lift cams with tight intake centerlines require flycutting/valve relief pistons. Eric L
