6010 no fire....please help!
Ok.... ohm checked all wiring and it each wire is about .1 to .2 resistence. so thats good. starter turns the car over faster or as fast as my 99 suburban and my 02f150. I don't think my box is necessarily bad but i do think it is taking way more than what it should to get it give spark. With that being said i called MSD and i asked them about a firmware or update of anything for that box and they just told me they would replace it with a new one. YEAH!! so all i can say is i was very please with the tech support of msd and all of you. ounce i get my new box i will let you know if it works. should be in a week
SO i am back.....and same problem. i got a new box and harness from MSD and it still has no spark unless i crank it without the plug in it and then it has spark. i called MSD and they said to put a washer behind the crank pos censor and try it. i haven't yet...that just sound not right to me. anyways they also said that it could be the reluctor wheel with missing teeth. Has anyone have any answer or suggestion. i looked that reluctor wheel and it seem ok and intact like it should be. the only and only thing i can think of is to change the crank and cam pos censor. i don't know what else to do.
Closed ex-Sponsor Account
Sounds like possibly poor grounding. Your voltage is slightly low also. Have you checked for a bad cell in the battery. If it fires with the plugs out then there is no need to space out the crank position sensor as it is picking up fine. You simply arent turning the motor over fast enough with the pl ugs in.
I don't think it is power or grounding. 10.6 volts when cranking sounds pretty good to me. I guess you could try hooking the box to second battery, maybe with a battery charger hooked up, to just to rule out anything with power to the box.
But if you don't have an RPM signal then it simply isn't going to start.
Some years ago guys with Callies cranks were having an impossible time getting an RPM signal in the MSD boxes. So it could be the crank. But haven't heard that one in some years.
IDK, At this point I would try a new crank sensor. Did you get a new harness with that replacement box? Any chance something is loose or bad there?
Maybe a weak starter? Is there anyway to tell what RPM it turns during crank?
By the way, the ignition doesn't need the cam sensor to produce a spark. The box will have a 50-50 chance of starting just fine with the cam sensor completely disconnected. So save a buck or two and don't bother with that right now.
#32
He said in the very first post he doesn't get an RPM reading with the plugs in, and then later says it does with them out.
Yet people kept talking about grounds.
Also just noticed he tried a new crank sensor too.
So the box can't see a crank signal unless the motor is cranking faster. I guess the question to answer now is whether the car is cranking too slow or if there is something seriously wrong with the reluctor.
This one sucks. I would say try borrowing a known good starter but you shouldn't have to go that route. Even with a weak battery the car should start.
What is the cranking RPM with the plugs out? Did anyone mess with the reluctor wheel?
#33
put a 16v battery in, and I will bet my *** it will fire.
6010 has a minimum RPM it must see before it allows the box to fire - I think it is 250rpm.
If youre not getting signal with the plugs in, its because the engine compression is slowing down the cranking RPM below the threshold the MSD box needs to see. Pull the plugs, no compression load on the starter, engine spins over faster, and you get spark and RPM signal from the MSD.
#35
Did this ever get resolved? I have similar issue. No spark. I try box on another vehicle and its good. Same w wiring harness. No spark. New crank sensor. New coils. New can sensor. No spark.
